Aller au contenu principal
Master and Dynamic MW50 Right/Left Speaker Replacement
Katie Dunnigan
Katie Dunnigan et 4 autres contributeurs
Dernière mise à jour le May 10, 2022
15 minutes
Difficile
If your speaker is not producing sound correctly, it may be necessary to replace the speaker component. This guide will show the five steps for removing the speaker. Soldering is required for this replacement, If you don't know how to solder or desolder, click here for a great guide.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: étape 1, image 1 de 3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: étape 1, image 2 de 3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: étape 1, image 3 de 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Right/Left Speaker Replacement: étape 2, image 1 de 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Right/Left Speaker Replacement: étape 3, image 1 de 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Right/Left Speaker Replacement, Right/Left Speaker: étape 4, image 1 de 1
    • Desolder the two wires connected to the speaker.
  5. Master and Dynamic MW50 Right/Left Speaker Replacement: étape 5, image 1 de 1
    • Use a heating gun to remove the glue from the speaker.
    • Once the glue is removed, gently pull out the speaker.
Katie Dunnigan
Membre depuis le 01/24/19
85 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S1-G4, White Winter 2019 Membre de l'équipe Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 membres
12 tutoriels rédigés
1 commentaire de tutoriel
This is awesome but Master & Dynamic don’t sell replacement 45mm 32 ohm drivers and won’t share the specs.
If anyone know where to get a replacement which will work well with these headphones please share!!!
paul
bloodygoose@icloud.com
psullivan_au - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 22
Total : 738
