Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Melitta Caffeo Solo outlet valve maintenance
Ce dont vous avez besoin
    1. Melitta Caffeo Solo outlet valve maintenance, Opening procedure: étape 1, image 1 de 1
      • Pull out the power cord!
      • Remove the water tank and drainage tray.
      • Remove the side cover and remove the brewing unit.
      • Remove all coffee beans.
      Demander à FixBot
      Ajouter un commentaire
    2. Melitta Caffeo Solo outlet valve maintenance: étape 2, image 1 de 1
      • Unscrew and remove six Torx T10 on the rear.
      • Lever the rear cover off. It will most likely be quite stuck and you will need to apply some force. You must use plastic lever tools to prevent damaging the cover.
      Demander à FixBot
    3. Melitta Caffeo Solo outlet valve maintenance: étape 3, image 1 de 2 Melitta Caffeo Solo outlet valve maintenance: étape 3, image 2 de 2
      • Press carefully into the slits on the sides using a minus screwdriver or a flat metal spatula, to release the clasps on the upper surface. These may be well tight and you have to use some force.
      • You should have created a separation between the upper surface and side panels. Now lever the upper covering away using a plastic tool. This may be quite stuck and you may apply some force.
      Demander à FixBot
    4. Melitta Caffeo Solo outlet valve maintenance: étape 4, image 1 de 1
      • Place a plastic tool in the crack between front panel and left side panel and widen it. Then push the side panel to the back. The side panel will be quite stuck and you may apply some force to do this.
      • Remove the hose from the water tank to the pump.
      • Remove the side panel.
      Demander à FixBot
    5. Melitta Caffeo Solo outlet valve maintenance: étape 5, image 1 de 1
      • Place a plastic tool into the crack between the front panel and the right side panel and widen it. Then push the side panel to the back. This may be quite stuck and you may need to apply some force.
      Demander à FixBot
    1. Melitta Caffeo Solo outlet valve maintenance, Outlet valve: étape 6, image 1 de 1
      • Look for the outlet valve on the top right of the device.
      Demander à FixBot
    2. Melitta Caffeo Solo outlet valve maintenance: étape 7, image 1 de 3 Melitta Caffeo Solo outlet valve maintenance: étape 7, image 2 de 3 Melitta Caffeo Solo outlet valve maintenance: étape 7, image 3 de 3
      • There are three latches securing the valve lid. Carefully lift the lid up using a metal spudger.
      • Lifting the lid exposes a spring, a plunger and its holder, an O-ring and the seal of the plunger. The photo shows clearly the imprint of the valve seat, so the valve doesn't close properly. The plunger tends to break but the spare plunger in the repair kit is made of metal.
      • Note the order and orientation of the parts (photo).
      • Alternatively you can replace the complete valve, it's not too expensive.
      Demander à FixBot
Follow the steps in reverse order to reassemble the device.
3 autres ont terminé cette réparation.
Merci à ces traducteurs :
de en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
VauWeh
Membre depuis le 10/19/15
342 605 Réputation
315 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 60
30 derniers jours : 273
Total : 13,279
