Introduction
The LCD screen is located directly on top of the motherboard and is attached by a cable underneath, which will need to be removed as well to replace the screen
Warning: The following guide is likely to ruin the water resistance of the device.
Ce dont vous avez besoin
Heat the iOpener. Instructions on how to do this can be found here: iOpener Instructions
Firmly press the frame of the band against the iOpener, and hold it in place for about 90 seconds.
Insert the spudger into the gap under the frame, and lightly slide it about 3/4 of the way down one of the long edges, then repeat with the other.
If the frame doesn't simply pop off, try sliding the spudger the rest of the way down the long edges, and lightly lift the frame with your fingers.
2 autres ont terminé cette réparation.
