Introduction
The frame is attached to the body of the Band with adhesive on the back side. This guide uses an iFixit iOpener to soften this adhesive so the frame can be removed.
Warning: The following guide is likely to ruin the water resistance of the device.
Ce dont vous avez besoin
Heat the iOpener. Instructions on how to do this can be found here: iOpener Instructions
Firmly press the frame of the band against the iOpener, and hold it in place for about 90 seconds.
Insert the spudger into the gap under the frame, and lightly slide it about 3/4 of the way down one of the long edges, then repeat with the other.
If the frame doesn't simply pop off, try sliding the spudger the rest of the way down the long edges, and lightly lift the frame with your fingers.
