Aller au contenu principal
Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement
Ce dont vous avez besoin
  1. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement, Casing: étape 1, image 1 de 2 Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement, Casing: étape 1, image 2 de 2
    • Warm up an iOpener following the instructions found in the iOpener guide.
    • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
  2. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 2, image 1 de 2 Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 2, image 2 de 2
    • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
    • This may take significant force. A fingernail might work better for the initial lift
    • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
  3. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 3, image 1 de 2 Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 3, image 2 de 2
    • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
    • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
  4. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 4, image 1 de 1
    • Flip the display over so that parts underneath it are easily accessible.
    • Do not pull out the display as it is still attached to the motherboard.
    • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
  5. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement, Audio Jack and MicroSD Slot: étape 5, image 1 de 1
    • You will be working in this area of the Surface 3 when replacing the audio jack and Micro SD port
  6. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 6, image 1 de 1
    • Remove the black adhesive covering next to the audio jack in order to get to the screws underneath.
  7. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 7, image 1 de 2 Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 7, image 2 de 2
    • Remove the silver bracket using the black pick in order to properly remove the entire audio jack.
  8. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 8, image 1 de 2 Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 8, image 2 de 2
    • Remove the two 3/16" Torx #2 screws directly beside the audio jack.
  9. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 9, image 1 de 2 Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 9, image 2 de 2
    • Remove the two 1/16" Torx #3 screws that hold in the MicroSD slot.
  10. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 10, image 1 de 2 Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: étape 10, image 2 de 2
    • Carefully remove the entire audio jack . It should look like the picture of the single part to the left.
4 autres ont terminé cette réparation.
Andy Stone
Membre depuis le 10/08/15
284 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 5-12, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 5-12, Maness Fall 2015
CPSU-MANESS-F15S5G12
4 membres
18 tutoriels rédigés
2 commentaires
Hi,
What is microsd bus interface? UHS-1 or UHS-2
Or at least, does it have any manufacturer info on it?
kemal - Réponse
Hi Guys,
Do you know where can I buy mini display port mounted on motherboard? I need aprox 100pcs.
Dan Bach - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 68
Total : 10,443
