Aller au contenu principal
Microsoft Surface 3 Kickstand Replacement
Ce dont vous avez besoin
  1. Microsoft Surface 3 Kickstand Replacement, Casing: étape 1, image 1 de 2 Microsoft Surface 3 Kickstand Replacement, Casing: étape 1, image 2 de 2
    • Warm up an iOpener following the instructions found in the iOpener guide.
    • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
  2. Microsoft Surface 3 Kickstand Replacement: étape 2, image 1 de 2 Microsoft Surface 3 Kickstand Replacement: étape 2, image 2 de 2
    • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
    • This may take significant force. A fingernail might work better for the initial lift
    • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
  3. Microsoft Surface 3 Kickstand Replacement: étape 3, image 1 de 2 Microsoft Surface 3 Kickstand Replacement: étape 3, image 2 de 2
    • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
    • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
  4. Microsoft Surface 3 Kickstand Replacement: étape 4, image 1 de 1
    • Flip the display over so that parts underneath it are easily accessible.
    • Do not pull out the display as it is still attached to the motherboard.
    • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
  5. Microsoft Surface 3 Kickstand Replacement, Battery: étape 5, image 1 de 1
    • Now that you've gotten the casing off of the Surface 3, you can start removing the battery pack.
  6. Microsoft Surface 3 Kickstand Replacement: étape 6, image 1 de 3 Microsoft Surface 3 Kickstand Replacement: étape 6, image 2 de 3 Microsoft Surface 3 Kickstand Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Slide the iFixit plastic cards under the compartments of the battery pack.
    • Slide the card around to undo the adhesive under the battery pack
  7. Microsoft Surface 3 Kickstand Replacement: étape 7, image 1 de 3 Microsoft Surface 3 Kickstand Replacement: étape 7, image 2 de 3 Microsoft Surface 3 Kickstand Replacement: étape 7, image 3 de 3
    • Carefully slide the battery's flat power and data connector from its insert.
    • You may now switch out the battery pack for a new one.
  8. Microsoft Surface 3 Kickstand Replacement, Kickstand: étape 8, image 1 de 2 Microsoft Surface 3 Kickstand Replacement, Kickstand: étape 8, image 2 de 2
    • Remove these four 3/32" Torx #3 screws.
    • If you do not need to remove the hinges, skip to the step that handles the retaining tabs.
  9. Microsoft Surface 3 Kickstand Replacement: étape 9, image 1 de 2 Microsoft Surface 3 Kickstand Replacement: étape 9, image 2 de 2
    • Remove these four 3/16" Torx #5 screws that hold in the hinges to replace the hinges.
  10. Microsoft Surface 3 Kickstand Replacement: étape 10, image 1 de 3 Microsoft Surface 3 Kickstand Replacement: étape 10, image 2 de 3 Microsoft Surface 3 Kickstand Replacement: étape 10, image 3 de 3
    • These two retaining tabs need to be fed through the slots in the case to release the kickstand.
    • Use picks to make the tab slide through the slot then simply pull out the kickstand,
4 autres ont terminé cette réparation.
Harold Hall
Membre depuis le 10/08/15
1 326 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 5-12, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 5-12, Maness Fall 2015
CPSU-MANESS-F15S5G12
4 membres
18 tutoriels rédigés
2 commentaires
I think I will NOT be trying to do this. To many potentials for something to go wrong beyond your control, even when being extra careful. I do not feel like replacing someone’s device if that happens.
QuickTech - Réponse
Please can you tell me which kickstand the surface pro 3 64 GB (2013) needs? Is it the same as the surface pro 4 ? I have broken the stand and am trying yo source a replacement.
Tilly Mortimore - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 12
30 derniers jours : 45
Total : 8,967
