Aller au contenu principal
Microsoft Surface Book 2 15" Headphone Jack Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Book 2 15" Headphone Jack Replacement, Motherboard: étape 1, image 1 de 1
    • Open the laptop, then orient it so the touchpad is on your left.
    • Starting at the hinge, count six holes up on the tablet portion of the laptop.
  2. Microsoft Surface Book 2 15" Headphone Jack Replacement: étape 2, image 1 de 2 Microsoft Surface Book 2 15" Headphone Jack Replacement: étape 2, image 2 de 2
    • Take a paper clip and unfold it.
    • Place the paperclip in the sixth hole and push until you hear a click.
    • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
    • After the right side has been detached, lift up the left side as well.
  3. Microsoft Surface Book 2 15" Headphone Jack Replacement: étape 3, image 1 de 1
    • Place the tablet on a flat surface.
    • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
  4. Microsoft Surface Book 2 15" Headphone Jack Replacement: étape 4, image 1 de 1
    • Using a plastic pick, slice underneath the edge of the screen.
    • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
    • Take care not to insert the tool too far to avoid cutting the ribbon cables.
    • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
    • Don't use a metal tool, that could damage the screen or internal parts.
  5. Microsoft Surface Book 2 15" Headphone Jack Replacement: étape 5, image 1 de 2 Microsoft Surface Book 2 15" Headphone Jack Replacement: étape 5, image 2 de 2
    • Lift up the screen.
    • Detach the ribbon cables connecting the underside of the screen to the motherboard.
  6. Microsoft Surface Book 2 15" Headphone Jack Replacement: étape 6, image 1 de 2 Microsoft Surface Book 2 15" Headphone Jack Replacement: étape 6, image 2 de 2
    • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
    • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
  7. Microsoft Surface Book 2 15" Headphone Jack Replacement: étape 7, image 1 de 1
    • Once the screws are removed from the top bar, gently lift up and remove it.
    • Be careful not to damage any ribbon cables or wires.
    • Gently lift up on the motherboard to remove it.
  8. Microsoft Surface Book 2 15" Headphone Jack Replacement, Headphone Jack: étape 8, image 1 de 2 Microsoft Surface Book 2 15" Headphone Jack Replacement, Headphone Jack: étape 8, image 2 de 2
    • Gently pull the headphone jack out of the slot.
  9. Microsoft Surface Book 2 15" Headphone Jack Replacement: étape 9, image 1 de 2 Microsoft Surface Book 2 15" Headphone Jack Replacement: étape 9, image 2 de 2
    • On the motherboard, unplug the ribbon cable connecting the headphone jack to the motherboard.
    • Flip up the latch on the connector and then pull out the cable.
Ryan Picewick
Membre depuis le 03/13/23
471 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-3, Petersen Spring 2023 Membre de l'équipe UMass Dartmouth, Team 3-3, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G3
4 membres
23 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 20
Total : 150
