Aller au contenu principal
Microsoft Surface Pro Speaker Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Pro Speaker Replacement, Heat edges of display: étape 1, image 1 de 1
    • Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
    • If you're using an iOpener it may take several cycles of reheating and applying it to soften the adhesive enough. Every time, let the iOpener sit on the display for at least a minute before reheating to allow the adhesive to soften.
  2. Microsoft Surface Pro Speaker Replacement, Lift display and cut adhesive: étape 2, image 1 de 3 Microsoft Surface Pro Speaker Replacement, Lift display and cut adhesive: étape 2, image 2 de 3 Microsoft Surface Pro Speaker Replacement, Lift display and cut adhesive: étape 2, image 3 de 3
    • Apply a suction cup as close as possible to the edge of the display.
    • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
    • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
    • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
    • The bezel is much thinner on the bottom of the display, which is the side with the Windows logo. To avoid damage, don't poke too deep with the opening pick on the bottom edge.
    • Ribbon cables and a circuit board are approx. 0.6 cm from the edge of the glass.
    • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
  3. Microsoft Surface Pro Speaker Replacement, Disconnect/peel off ribbon cables: étape 3, image 1 de 3 Microsoft Surface Pro Speaker Replacement, Disconnect/peel off ribbon cables: étape 3, image 2 de 3 Microsoft Surface Pro Speaker Replacement, Disconnect/peel off ribbon cables: étape 3, image 3 de 3
    • Starting from the top edge, lift the display slightly.
    • If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
    • Before completely removing the display:
    • Disconnect the three display cables.
    • Gently peel from the frame 2 orange ribbon cables that are glued to it, as those should stay with the display. (e.g. use a thin plastic card to separate them)
  4. Microsoft Surface Pro Speaker Replacement, Removal: étape 4, image 1 de 1
    • Remove the display.
  5. Microsoft Surface Pro Speaker Replacement, Speaker: étape 5, image 1 de 2 Microsoft Surface Pro Speaker Replacement, Speaker: étape 5, image 2 de 2
    • Unscrew all the 23 screws located on the outside panel with the T5 torx screw driver
  6. Microsoft Surface Pro Speaker Replacement: étape 6, image 1 de 1
    • Use the plastic opening tool to pry out the cameras
  7. Microsoft Surface Pro Speaker Replacement: étape 7, image 1 de 1
    • Pull the outside panel with your hands from the Surface Pro
  8. Microsoft Surface Pro Speaker Replacement: étape 8, image 1 de 2 Microsoft Surface Pro Speaker Replacement: étape 8, image 2 de 2
    • Use the T5 torx screw driver to unscrew the 6 T5 screws located on the left and right metal panels
    • Use the T2 torx screw driver to unscrew the 23 T2 screws located on the left and right metal panels
  9. Microsoft Surface Pro Speaker Replacement: étape 9, image 1 de 1
    • Gently pull out left and right metal panels with hands
  10. Microsoft Surface Pro Speaker Replacement: étape 10, image 1 de 2 Microsoft Surface Pro Speaker Replacement: étape 10, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Disconnect the two speakers with tweezers
    • Gently pry out the speakers with spudger
Jonathan Choi
Membre depuis le 10/09/13
1 029 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 8-20, Regan Fall 2013 Membre de l'équipe Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 21
Total : 3,264
