Aller au contenu principal
Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement
Ce dont vous avez besoin
  1. Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Orient your saw sideways so that the blade is facing downwards.
  2. Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: étape 2, image 1 de 3 Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: étape 2, image 2 de 3 Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: étape 2, image 3 de 3
    • Remove the nine 6 mm screws using a Torx T4 screwdriver.
    • Remove the single 8 mm screw at the bottom that attaches the panels together using a Torx T6 screwdriver.
    • Slowly pull and remove the front panel of the saw that connects to the blade side with your hand, and separate it from the motor.
  3. Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement, Battery: étape 3, image 1 de 1
    • Slowly remove the battery from its slot with your hand while watching out for the spring below.
    • Remove the spring that is located under the battery compartment and set it aside for later.
  4. Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Carefully remove the rubber covers from the black and red wires of the battery with a pair of tweezers.
  5. Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: étape 5, image 1 de 3 Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: étape 5, image 2 de 3 Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: étape 5, image 3 de 3
    • Carefully desolder and separate the wires from the battery compartment.
    • Gently pull the wires off with your hands being careful of the heat.
Snehith Reddy
Membre depuis le 09/12/23
97 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 89
