Introduction
A mortise lock is a vital component of your door's security and functionality, and when it breaks, it's important to address the issue promptly and correctly. In this guide, we'll walk you through the steps of replacing a mortise lock.
Ce dont vous avez besoin
Outil utilisé dans cette étape :iFixit Precision 4 mm Screwdriver Bit$2.99
Unscrew the set screw holding the door handle using a 3mm hex key.
Remove the two screws securing the lock to the doorframe.
Pull the lock out towards you.
Presque terminé !
