Introduction
This guide will show you how to apply new adhesive to the rear cover of your Motorola Droid Turbo 2 to seal it up after a repair.
Ce dont vous avez besoin
Prepare the phone frame surface by removing all traces of adhesive.
Use tweezers to pull adhesive chunks off. Use the opening tool to scrape residue off. You can use high concentration (over 90%) isopropyl alcohol to help dissolve residue.
If you are re-using the rear cover, prepare the inner surface by removing all traces of adhesive from it.
Set the pre-cut adhesive strip next to the rear cover so that it is properly oriented—the pull tabs should point to the bottom left corner of the cover.
Lay the pre-cut adhesive strip over the rear cover, aligning it to the long edges.
Tape one long edge of the pre-cut adhesive strip to the rear cover, locking the alignment in place while allowing the strip to still swing.
Repair didn’t go as planned? Check out our Motorola Droid Turbo 2 Answers community for troubleshooting help.
8 autres ont terminé cette réparation.
