Aller au contenu principal
Motorola MC5590 Speaker Replacement
Ce dont vous avez besoin
  1. Motorola MC5590 Speaker Replacement, Battery: étape 1, image 1 de 1
    • Push in the battery release button.
  2. Motorola MC5590 Speaker Replacement: étape 2, image 1 de 1
    • Pull out battery.
  3. Motorola MC5590 Speaker Replacement, Keyboard: étape 3, image 1 de 2 Motorola MC5590 Speaker Replacement, Keyboard: étape 3, image 2 de 2
    • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
  4. Motorola MC5590 Speaker Replacement: étape 4, image 1 de 3 Motorola MC5590 Speaker Replacement: étape 4, image 2 de 3 Motorola MC5590 Speaker Replacement: étape 4, image 3 de 3
    • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
  5. Motorola MC5590 Speaker Replacement: étape 5, image 1 de 1
    • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
  6. Motorola MC5590 Speaker Replacement: étape 6, image 1 de 2 Motorola MC5590 Speaker Replacement: étape 6, image 2 de 2
    • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
  7. Motorola MC5590 Speaker Replacement: étape 7, image 1 de 1
    • Remove the keyboard cover.
  8. Motorola MC5590 Speaker Replacement: étape 8, image 1 de 3 Motorola MC5590 Speaker Replacement: étape 8, image 2 de 3 Motorola MC5590 Speaker Replacement: étape 8, image 3 de 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  9. Motorola MC5590 Speaker Replacement: étape 9, image 1 de 2 Motorola MC5590 Speaker Replacement: étape 9, image 2 de 2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Remove the keyboard from the device.
  10. Motorola MC5590 Speaker Replacement, Speaker: étape 10, image 1 de 2 Motorola MC5590 Speaker Replacement, Speaker: étape 10, image 2 de 2
    • Pull the black rubber tabs up gently and remove them.
  11. Motorola MC5590 Speaker Replacement: étape 11, image 1 de 2 Motorola MC5590 Speaker Replacement: étape 11, image 2 de 2
    • Using your finger, or spudger, push the motherboard out from the bottom.
  12. Motorola MC5590 Speaker Replacement: étape 12, image 1 de 2 Motorola MC5590 Speaker Replacement: étape 12, image 2 de 2
    • Remove the three Phillips #00 screws from the motherboard:
    • Two 3mm screws.
    • One 1mm screw.
  13. Motorola MC5590 Speaker Replacement: étape 13, image 1 de 2 Motorola MC5590 Speaker Replacement: étape 13, image 2 de 2
    • Disconnect the speaker from the motherboard.
Tyler Jean
Membre depuis le 02/22/18
555 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G6, Cagle Spring 2018 Membre de l'équipe USF Tampa, Team S1-G6, Cagle Spring 2018
USFT-CAGLE-S18S1G6
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 157
