Introduction
The back camera of the Motorola Moto E6 Play phone is a 13MP, ƒ/2.2, 1.12 µm pixel camera with a LED flash and a PDAF (phase detection autofocus) feature. It also has MPEG-4/H.263/H.264 video capture.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
If you are experiencing the ‘Camera Busy’ error, click here for troubleshooting solutions. However, if you are experiencing other issues with the back camera, or the troubleshooting guides do not solve the problem, you may need to replace the camera.
Ce dont vous avez besoin
Run the halberd spudger along the edges of the device. The back cover should easily pop off.
To remove the cover on the motherboard, remove the 10 silver 3.90 mm Phillips screws attaching the cover to the board using the Phillips #0 screwdriver.
With the angled tweezers, remove the black cover to reveal the motherboard underneath.
Use the angled tweezers to pry off the metal head of the connecting piece from the main motherboard assembly.
