Introduction
The front camera of the Motorola Moto E6 Play phone is a 5MP, f2.2, 1.12 µm pixel camera. If you are experiencing the ‘Camera Busy’ error, click here for troubleshooting solutions. However, if you are experiencing other issues with the front camera, or the troubleshooting guides do not solve the problem, you may need to replace the camera.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Halberd Spudger$2.99
Run the halberd spudger along the edges of the device. The back cover should easily pop off.
To remove the cover on the motherboard, remove the 10 silver 3.90 mm Phillips screws attaching the cover to the board using the Phillips #0 screwdriver.
Outil utilisé dans cette étape :Tweezers$3.99
With the angled tweezers, remove the black cover to reveal the motherboard underneath.
Use the angled tweezers to pry off the metal head of the connecting piece from the main motherboard assembly.
