Aller au contenu principal
Motorola Moto E6 Plus Front Camera Replacement
Ce dont vous avez besoin
  1. Motorola Moto E6 Plus Front Camera Replacement, Unclip the back cover: étape 1, image 1 de 2 Motorola Moto E6 Plus Front Camera Replacement, Unclip the back cover: étape 1, image 2 de 2
    • Use an opening tool or your fingernail to pry the back cover away from the frame using the notch at the bottom right corner.
  2. Motorola Moto E6 Plus Front Camera Replacement, Unclip the right edge: étape 2, image 1 de 3 Motorola Moto E6 Plus Front Camera Replacement, Unclip the right edge: étape 2, image 2 de 3 Motorola Moto E6 Plus Front Camera Replacement, Unclip the right edge: étape 2, image 3 de 3
    • Use an opening tool or your fingernail to release the clips on the right edge by sliding up and around the top right corner.
  3. Motorola Moto E6 Plus Front Camera Replacement, Unclip the top edge: étape 3, image 1 de 2 Motorola Moto E6 Plus Front Camera Replacement, Unclip the top edge: étape 3, image 2 de 2
    • Continue to slide the opening tool or your fingernail across the top edge to release the clips securing the back cover to the frame.
  4. Motorola Moto E6 Plus Front Camera Replacement, Unclip the left edge: étape 4, image 1 de 2 Motorola Moto E6 Plus Front Camera Replacement, Unclip the left edge: étape 4, image 2 de 2
    • Continue to slide the opening tool or your fingernail down the left edge to release the clips.
  5. Motorola Moto E6 Plus Front Camera Replacement, Remove the back cover: étape 5, image 1 de 3 Motorola Moto E6 Plus Front Camera Replacement, Remove the back cover: étape 5, image 2 de 3 Motorola Moto E6 Plus Front Camera Replacement, Remove the back cover: étape 5, image 3 de 3
    • Remove the back cover.
  6. Motorola Moto E6 Plus Front Camera Replacement, Remove the SIM and SD cards: étape 6, image 1 de 3 Motorola Moto E6 Plus Front Camera Replacement, Remove the SIM and SD cards: étape 6, image 2 de 3 Motorola Moto E6 Plus Front Camera Replacement, Remove the SIM and SD cards: étape 6, image 3 de 3
    • Use a spudger or your fingernail to remove the Micro SD card, the Micro SIM card, and the Nano SIM card.
  7. Motorola Moto E6 Plus Front Camera Replacement, Remove the white sticker: étape 7, image 1 de 2 Motorola Moto E6 Plus Front Camera Replacement, Remove the white sticker: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to remove the sticker covering the screw below the audio jack port.
  8. Motorola Moto E6 Plus Front Camera Replacement, Remove the screws: étape 8, image 1 de 1
    • Use a Torx T3 driver to remove the five 3.6 mm-long screws securing the motherboard cover to the frame.
    • Use a Phillips screwdriver to remove the two 3.1 mm-long screws.
  9. Motorola Moto E6 Plus Front Camera Replacement, Peel back the button sticker: étape 9, image 1 de 2 Motorola Moto E6 Plus Front Camera Replacement, Peel back the button sticker: étape 9, image 2 de 2
    • Use a pair of tweezers to peel back the sticker covering the volume buttons.
  10. Motorola Moto E6 Plus Front Camera Replacement, Pry up the motherboard cover: étape 10, image 1 de 3 Motorola Moto E6 Plus Front Camera Replacement, Pry up the motherboard cover: étape 10, image 2 de 3 Motorola Moto E6 Plus Front Camera Replacement, Pry up the motherboard cover: étape 10, image 3 de 3
    • Use an opening tool to release the clip to the left of the motherboard flex cable.
  11. Motorola Moto E6 Plus Front Camera Replacement: étape 11, image 1 de 2 Motorola Moto E6 Plus Front Camera Replacement: étape 11, image 2 de 2
    • Insert a spudger along the left edge of the motherboard cover to loosen the clips.
  12. Motorola Moto E6 Plus Front Camera Replacement, Pry up the motherboard cover: étape 12, image 1 de 3 Motorola Moto E6 Plus Front Camera Replacement, Pry up the motherboard cover: étape 12, image 2 de 3 Motorola Moto E6 Plus Front Camera Replacement, Pry up the motherboard cover: étape 12, image 3 de 3
    • Use an opening tool to release the clip next to the rear cameras.
  13. Motorola Moto E6 Plus Front Camera Replacement: étape 13, image 1 de 3 Motorola Moto E6 Plus Front Camera Replacement: étape 13, image 2 de 3 Motorola Moto E6 Plus Front Camera Replacement: étape 13, image 3 de 3
    • Use a pair of tweezers to peel off the sticker on the top edge of the motherboard cover.
  14. Motorola Moto E6 Plus Front Camera Replacement, Pry up the motherboard cover: étape 14, image 1 de 2 Motorola Moto E6 Plus Front Camera Replacement, Pry up the motherboard cover: étape 14, image 2 de 2
    • Use a spudger to lift up the left edge of the motherboard cover to loosen the clips.
  15. Motorola Moto E6 Plus Front Camera Replacement, Dislodge the fingerprint sensor: étape 15, image 1 de 2 Motorola Moto E6 Plus Front Camera Replacement, Dislodge the fingerprint sensor: étape 15, image 2 de 2
    • Use a spudger to push and dislodge the fingerprint sensor off of the motherboard cover.
    • The fingerprint sensor is secured to the underside of the motherboard cover with some light adhesive.
  16. Motorola Moto E6 Plus Front Camera Replacement, Remove the motherboard cover: étape 16, image 1 de 3 Motorola Moto E6 Plus Front Camera Replacement, Remove the motherboard cover: étape 16, image 2 de 3 Motorola Moto E6 Plus Front Camera Replacement, Remove the motherboard cover: étape 16, image 3 de 3
    • Use your fingers to twist the motherboard cover counterclockwise to release the clips securing the motherboard cover.
  17. Motorola Moto E6 Plus Front Camera Replacement: étape 17, image 1 de 2 Motorola Moto E6 Plus Front Camera Replacement: étape 17, image 2 de 2
    • Remove the motherboard cover.
  18. Motorola Moto E6 Plus Front Camera Replacement, Peel back the tape: étape 18, image 1 de 2 Motorola Moto E6 Plus Front Camera Replacement, Peel back the tape: étape 18, image 2 de 2
    • Use a pair of tweezers to peel back the tape securing the front camera to the motherboard.
  19. Motorola Moto E6 Plus Front Camera Replacement, Remove the front camera: étape 19, image 1 de 3 Motorola Moto E6 Plus Front Camera Replacement, Remove the front camera: étape 19, image 2 de 3 Motorola Moto E6 Plus Front Camera Replacement, Remove the front camera: étape 19, image 3 de 3
    • Use the flat end of a spudger to lift the front camera's press connector straight up to disconnect it from the motherboard.
    • Remove the front camera.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto E6 Plus Answers community for help.
Robert Boyd
Membre depuis le 02/01/21
29 860 Réputation
94 tutoriels rédigés
1 commentaire de tutoriel
Você é o cara!
Silas Sousa - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 273
