Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Motorola Moto G 1st Generation Headphone Jack Replacement
Ce dont vous avez besoin
  1. Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: étape 1, image 1 de 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: étape 1, image 2 de 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: étape 1, image 3 de 3
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
  2. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Screws: étape 2, image 1 de 1
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
  3. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Battery Cover: étape 3, image 1 de 2 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Battery Cover: étape 3, image 2 de 2
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: étape 4, image 1 de 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: étape 4, image 2 de 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: étape 4, image 3 de 3
    • Use the plastic opening tool to remove the Headphone Jack from the protective cover and replace it.
Radostin Lobodov
Membre depuis le 10/16/14
2 946 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G7
3 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 23
Total : 2,530
