Aller au contenu principal
Motorola Moto G 5G (2022) Power Button Replacement
Ce dont vous avez besoin
  1. Motorola Moto G 5G (2022) Power Button Replacement, Eject the SIM card tray: étape 1, image 1 de 2 Motorola Moto G 5G (2022) Power Button Replacement, Eject the SIM card tray: étape 1, image 2 de 2
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
  2. Motorola Moto G 5G (2022) Power Button Replacement, Remove the SIM card tray: étape 2, image 1 de 1
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
  3. Motorola Moto G 5G (2022) Power Button Replacement, Back cover removal information: étape 3, image 1 de 2 Motorola Moto G 5G (2022) Power Button Replacement, Back cover removal information: étape 3, image 2 de 2
    • Discharge your battery to 25% or less and completely power off your phone before you begin.
    • Take note of the following seams along the edge of the phone:
    • Screen seam: This seam separates the display panel from the frame. Don't pry at this seam.
    • Bezel seam: This is where the plastic back cover meets the rest of the phone. It's held in place by plastic clips. This is where you should pry.
  4. Motorola Moto G 5G (2022) Power Button Replacement, Insert an opening pick: étape 4, image 1 de 3 Motorola Moto G 5G (2022) Power Button Replacement, Insert an opening pick: étape 4, image 2 de 3 Motorola Moto G 5G (2022) Power Button Replacement, Insert an opening pick: étape 4, image 3 de 3
    • Insert an opening tool in the bezel seam halfway between the bottom-right corner of the phone and the power button.
    • Insert an opening pick in the gap you just created.
  5. Motorola Moto G 5G (2022) Power Button Replacement, Release the right clips: étape 5, image 1 de 2 Motorola Moto G 5G (2022) Power Button Replacement, Release the right clips: étape 5, image 2 de 2
    • Slide your opening pick toward the bottom-right corner of the back cover and release the clips.
    • As each clip releases, you will hear and feel a pop.
    • Don't slide the opening pick near the power or volume buttons.
  6. Motorola Moto G 5G (2022) Power Button Replacement, Release the bottom clips: étape 6, image 1 de 2 Motorola Moto G 5G (2022) Power Button Replacement, Release the bottom clips: étape 6, image 2 de 2
    • Continue sliding your opening pick towards the bottom left corner to unclip the bottom edge of the back cover.
  7. Motorola Moto G 5G (2022) Power Button Replacement, Release the left clips: étape 7, image 1 de 3 Motorola Moto G 5G (2022) Power Button Replacement, Release the left clips: étape 7, image 2 de 3 Motorola Moto G 5G (2022) Power Button Replacement, Release the left clips: étape 7, image 3 de 3
    • Slide your opening pick toward the top left corner to unclip the left side of the back cover.
  8. Motorola Moto G 5G (2022) Power Button Replacement, Release the top clips: étape 8, image 1 de 2 Motorola Moto G 5G (2022) Power Button Replacement, Release the top clips: étape 8, image 2 de 2
    • Slide your pick around the top left corner and along the top edge to release the clips.
  9. Motorola Moto G 5G (2022) Power Button Replacement: étape 9, image 1 de 2 Motorola Moto G 5G (2022) Power Button Replacement: étape 9, image 2 de 2
    • Slide your pick around the top right corner to release the last clips securing the back cover.
    • Stop before reaching the volume buttons. Your pick may damage their cables.
  10. Motorola Moto G 5G (2022) Power Button Replacement, Remove the back cover: étape 10, image 1 de 3 Motorola Moto G 5G (2022) Power Button Replacement, Remove the back cover: étape 10, image 2 de 3 Motorola Moto G 5G (2022) Power Button Replacement, Remove the back cover: étape 10, image 3 de 3
    • Don't try to remove the back cover all the way yet, as it's still connected to the frame by the power button cable.
    • With SIM card slot facing you, swing the back cover open and away from you like you're opening a book.
    • Rest the cover parallel to the frame.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the power button cable.
  11. Motorola Moto G 5G (2022) Power Button Replacement, Remove the power button: étape 11, image 1 de 2 Motorola Moto G 5G (2022) Power Button Replacement, Remove the power button: étape 11, image 2 de 2
    Outil utilisé dans cette étape :
    • A small rubber arm connects the power button to its recess. Use caution to avoid tearing this piece.
    • Use tweezers or your fingers to unhook the power button's rubber arm from its recess and remove it.
  12. Motorola Moto G 5G (2022) Power Button Replacement, Only the back cover remains: étape 12, image 1 de 1
    • You're now left with the back cover.
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
  13. Motorola Moto G 5G (2022) Power Button Replacement, Unfasten the power button cable bracket: étape 13, image 1 de 2 Motorola Moto G 5G (2022) Power Button Replacement, Unfasten the power button cable bracket: étape 13, image 2 de 2
    • Use a PH00 screwdriver to remove the two 3.9 mm-long screws securing the power button cable bracket.
  14. Motorola Moto G 5G (2022) Power Button Replacement, Remove the power button cable bracket: étape 14, image 1 de 2 Motorola Moto G 5G (2022) Power Button Replacement, Remove the power button cable bracket: étape 14, image 2 de 2
    • Use your fingers or a pair of blunt nose tweezers to grab and remove the bracket from the power button cable.
  15. Motorola Moto G 5G (2022) Power Button Replacement, Disconnect the power button: étape 15, image 1 de 2 Motorola Moto G 5G (2022) Power Button Replacement, Disconnect the power button: étape 15, image 2 de 2
    • Use the pointed end of a spudger to pry up and disconnect the power button's press connector.
  16. Motorola Moto G 5G (2022) Power Button Replacement, Remove the power button: étape 16, image 1 de 2 Motorola Moto G 5G (2022) Power Button Replacement, Remove the power button: étape 16, image 2 de 2
    • Grab and remove the power button.
    • If you're using tweezers, take care not to puncture the battery—a punctured battery may leak dangerous chemicals or cause a fire.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
3 autres ont terminé cette réparation.
Clay Eickemeyer
Membre depuis le 09/19/22
95 599 Réputation
466 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 32
30 derniers jours : 195
Total : 5,900
