Aller au contenu principal
Motorola Moto G3 Motherboard Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Motorola Moto G3 Motherboard  Replacement, Prerequisite Guide: étape 1, image 1 de 2 Motorola Moto G3 Motherboard  Replacement, Prerequisite Guide: étape 1, image 2 de 2
    • Use the plastic opening tool to open the back cover as shown in the photo.
  2. Motorola Moto G3 Motherboard  Replacement: étape 2, image 1 de 1
    • Heat an iOpener in the microwave for 30 seconds.
    • Place the heated iOpener on all four edges of the screen for approximately 2 minutes.
  3. Motorola Moto G3 Motherboard  Replacement: étape 3, image 1 de 1
    • Apply the plastic opening tool on the edge of the screen near the front camera.
    • After creating enough space, allow the opening tool to be inserted on the side of the phone.
    • Create another space on the other side of the screen.
    • Leave the opening tool inserted.
    • Carefully apply the larger plastic opening tool by sliding it through the longer edge of the screen.
  4. Motorola Moto G3 Motherboard  Replacement: étape 4, image 1 de 3 Motorola Moto G3 Motherboard  Replacement: étape 4, image 2 de 3 Motorola Moto G3 Motherboard  Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • A strip will be attached to the motherboard as shown.
    • Using tweezers, carefully detach the strip from the motherboard.
  5. Motorola Moto G3 Motherboard  Replacement, Motherboard: étape 5, image 1 de 3 Motorola Moto G3 Motherboard  Replacement, Motherboard: étape 5, image 2 de 3 Motorola Moto G3 Motherboard  Replacement, Motherboard: étape 5, image 3 de 3
    • With a T4 screwdriver, remove the10 "yellow" 2mm screws and 4 "black" 2mm screws.
  6. Motorola Moto G3 Motherboard  Replacement: étape 6, image 1 de 2 Motorola Moto G3 Motherboard  Replacement: étape 6, image 2 de 2
    • Use the metal spudger and lift the back cover on the bottom side of the phone (this is attached to the motherboard).
    • Remove the motherboard from the device.
3 autres ont terminé cette réparation.
Irkan Notta
Membre depuis le 03/19/18
1 034 Réputation
7 tutoriels rédigés
Équipe
Baylor, Team S5-G3, Williams Spring 2018 Membre de l'équipe Baylor, Team S5-G3, Williams Spring 2018
BU-WILLIAMS-S18S5G3
3 membres
9 tutoriels rédigés
Un commentaire
i broke my battery connectig port where we plug in the battery. What should i do?
PLZ answer
All you need to Know (SAMMY) - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 483
