Aller au contenu principal
Nest x Yale Lock Keypad Replacement
Ce dont vous avez besoin
  1. Nest x Yale Lock Keypad Replacement, Keypad: étape 1, image 1 de 1
    • Unscrew all available screws that you can see from the back.
    • The screws are 0.25 inches phillips screws.
    • Make sure to not lose any of the screws, and keep track of them.
  2. Nest x Yale Lock Keypad Replacement: étape 2, image 1 de 1
    • Once you have unscrewed all the screws carefully remove the metal covering.
    • Make sure that the wire safely goes through the hole.
  3. Nest x Yale Lock Keypad Replacement: étape 3, image 1 de 1
    • Then once again unscrew the two screws that you see.
    • The screws have a height of 0.2 inches phillips screws.
  4. Nest x Yale Lock Keypad Replacement: étape 4, image 1 de 2 Nest x Yale Lock Keypad Replacement: étape 4, image 2 de 2
    • Once all screws are unscrewed proceed to tap the screen out of the metal casing.
Christopher Gonzalez
Membre depuis le 09/26/22
313 Réputation
3 tutoriels rédigés
Équipe
CSU Los Angeles, Team 5-3, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-3, Adachi Fall 2022
CSULA-ADACHI-F22S5G3
5 membres
5 tutoriels rédigés
Un commentaire
Where do you order the touchscreen from?
Mike Turrell - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 16
Total : 365
