Aller au contenu principal
Nest x Yale Lock Motherboard Replacement
Ce dont vous avez besoin
  1. Nest x Yale Lock Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Before proceeding, make sure the batteries are removed to avoid being electrocuted and damage to the lock
    • If you do not know how to remove the batteries then I would recommend looking at our battery replacement guide for help.
  2. Nest x Yale Lock Motherboard Replacement: étape 2, image 1 de 2 Nest x Yale Lock Motherboard Replacement: étape 2, image 2 de 2
    • Remove 3 screws as shown to remove the first cover.
    • The 3 screws are 0.25 inches length
  3. Nest x Yale Lock Motherboard Replacement: étape 3, image 1 de 1
    • Using a pin to push down the knot holding the wire and the tweezer to safely remove the wire from the motherboard
  4. Nest x Yale Lock Motherboard Replacement: étape 4, image 1 de 2 Nest x Yale Lock Motherboard Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a spudger or plastic tool to lift the ZIF lock upward (as shown in the first picture).
    • Use tweezers to remove the ribbon cable from the motherboard.
  5. Nest x Yale Lock Motherboard Replacement: étape 5, image 1 de 1
    • Continue to remove 2 screws holding the motherboard to the lock shell.
    • The screws are 0.20 inches in length.
  6. Nest x Yale Lock Motherboard Replacement: étape 6, image 1 de 2 Nest x Yale Lock Motherboard Replacement: étape 6, image 2 de 2
    • Use an opening tool to push the motherboard out as shown in the picture.
Bryant Duong
Membre depuis le 09/26/22
379 Réputation
2 tutoriels rédigés
Équipe
CSU Los Angeles, Team 5-3, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-3, Adachi Fall 2022
CSULA-ADACHI-F22S5G3
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 14
Total : 400
