Aller au contenu principal
Nest x Yale Lock Speaker Replacement
Ce dont vous avez besoin
  1. Nest x Yale Lock Speaker Replacement, Speaker: étape 1, image 1 de 3 Nest x Yale Lock Speaker Replacement, Speaker: étape 1, image 2 de 3 Nest x Yale Lock Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Get the lock device and turn it around.
    • Take out the black cover by removing the screws as shown in picture #1 and pull it out gently just so.
    • All 3 screws are 0.25 inches high and are phillip screws.
    • Doing so gains access to the motherboard as shown in picture #3.
  2. Nest x Yale Lock Speaker Replacement: étape 2, image 1 de 2 Nest x Yale Lock Speaker Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • On the white connector in picture #1, push down using a pointed tip object and then remove the connection using tweezers.
    • For the wider connection in picture #2, lift up the black switch and remove the connection using tweezers.
  3. Nest x Yale Lock Speaker Replacement: étape 3, image 1 de 2 Nest x Yale Lock Speaker Replacement: étape 3, image 2 de 2
    • Take out the motherboard by unscrewing the screws holding it shown in picture #1.
    • The screws are phillips and are 0.25 inches.
    • After removing the screw on the motherboard, pry the motherboard out using a prying tool shown in picture #2.
  4. Nest x Yale Lock Speaker Replacement: étape 4, image 1 de 1
    • The small black part on the down right side of the motherboard is the audio.
Christopher Gonzalez
Membre depuis le 09/26/22
313 Réputation
3 tutoriels rédigés
Équipe
CSU Los Angeles, Team 5-3, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-3, Adachi Fall 2022
CSULA-ADACHI-F22S5G3
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 6
30 derniers jours : 16
Total : 263
