Aller au contenu principal
Newport HT70 Pump Assembly Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Newport HT70 Pump Assembly Replacement, Pump Assembly: étape 1, image 1 de 1
    • Position the base assembly so that you may access it.
    • Using the #1 Phillips screwdriver, unscrew the four screws (SCR3219P in the photo) and the two screws (SCR3232P) securing the base plate.
  2. Newport HT70 Pump Assembly Replacement: étape 2, image 1 de 1
    • The base plate will then come apart from the rest of the device with the pump assembly attached to it, as depicted in the following photo.
    • Inspect pump assembly for any damage or looseness.
  3. Newport HT70 Pump Assembly Replacement: étape 3, image 1 de 1
    • If damage is found, replace the pump assembly by removing each tube individually and replacing as needed.
    • You may not need to replace the entire assembly if parts of it are still intact.
Merek McGill
Membre depuis le 04/07/20
520 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S7-G5, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G5, Paton Spring 2020
CPSU-PATON-S20S7G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 222
