Introduction
Remove the circuit board cover so they can proceed to remove the circuit board or fix the lens.
Pièces
Aucune pièce nécessaire.
  1. Place thumb on the battery cover panel on the bottom of the device.
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Slide the orange latch outward towards the corner of the camera. The battery should pop out.
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  6. Unscrew the two 4.05mm screws on the side next to the buttons.
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  7. Gently wedge the flat end of the spudger between the back case and the wrist-strap mount. The wrist-strap mount is the thin metal piece on the side of the camera.  Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  8. Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon. The ribbons are connected to and held in place by small plastic latches. To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up.  The ribbon should slide out easily.
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  9. Gently remove the LCD screen.
    • Gently remove the LCD screen.
  10. After removing the LCD screen, unscrew the four 3.8mm screws that hold down the metal plate
    • After removing the LCD screen, unscrew the four 3.8mm screws that hold down the metal plate
    • Unscrew the 2.5mm screw next to the wrist-strap mount.
  11. Position the camera with the lens facing down and the shutter button facing you. Lift the metal plate away from the camera without removing it fully.  There is a ribbon attaching the edge of the plate to the camera.
    • Position the camera with the lens facing down and the shutter button facing you.
    • Lift the metal plate away from the camera without removing it fully. There is a ribbon attaching the edge of the plate to the camera.
    • The ribbon is being held in place by a black latch.
    • Carefully pry the spudger under the black latch and lift gently upward. The ribbon will slide out easily.
    • With the ribbon unlatched, the entire metal plate should now be detached.
Paul Doyle
Membre depuis le 20/01/2011
470 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 5-17, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 membres
7 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 1,742
