Introduction
If your Nikon D3100 LCD screen is cracked, chipped, or flickering it may need to be replaced. Follow this guide to replace the LCD screen. But first take a look at this troubleshooting page to check if the problem is truly the LCD screen and not a setting issue.
Ce dont vous avez besoin
Remove two of the 4mm screws indicated by the circles on the bottom side of the camera.
Starting from the top, gently lift the back panel of the camera off. Slowly separate the back panel from the main body of the camera.
Carefully remove the ribbon using a spudger to lift up the connector and then use tweezers to pull out the ribbon.
Separate the back panel from the main body of the camera.
7 autres ont terminé cette réparation.
5 commentaires
Very helpful guide, so happy to have a non-cracked screen again!
now, where can i buy this replacement screen here in the Philippines?
does anyone have the part number for the replacement screen?
Hello, regarde ici ça devrait correspondre:
