Aller au contenu principal
Nikon D7000 Motherboard Replacement
Ce dont vous avez besoin
  1. Nikon D7000 Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Motherboard Replacement: étape 2, image 1 de 1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Motherboard Replacement: étape 3, image 1 de 2 Nikon D7000 Motherboard Replacement: étape 3, image 2 de 2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Motherboard Replacement: étape 4, image 1 de 1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Motherboard Replacement: étape 5, image 1 de 1
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Motherboard Replacement: étape 6, image 1 de 1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Motherboard Replacement: étape 7, image 1 de 1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Motherboard Replacement: étape 8, image 1 de 1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Motherboard Replacement: étape 9, image 1 de 1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Motherboard Replacement: étape 10, image 1 de 1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Motherboard Replacement: étape 11, image 1 de 1
    • Gently pull the SD card cover off.
  12. Nikon D7000 Motherboard Replacement: étape 12, image 1 de 1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Motherboard Replacement: étape 13, image 1 de 1
    • Carefully lift the back case off.
  14. Nikon D7000 Motherboard Replacement: étape 14, image 1 de 3 Nikon D7000 Motherboard Replacement: étape 14, image 2 de 3 Nikon D7000 Motherboard Replacement: étape 14, image 3 de 3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Motherboard Replacement: étape 15, image 1 de 2 Nikon D7000 Motherboard Replacement: étape 15, image 2 de 2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Motherboard Replacement: étape 16, image 1 de 1
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Motherboard Replacement: étape 17, image 1 de 1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Motherboard Replacement: étape 18, image 1 de 1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Motherboard Replacement: étape 19, image 1 de 3 Nikon D7000 Motherboard Replacement: étape 19, image 2 de 3 Nikon D7000 Motherboard Replacement: étape 19, image 3 de 3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Motherboard Replacement: étape 20, image 1 de 2 Nikon D7000 Motherboard Replacement: étape 20, image 2 de 2
  21. Nikon D7000 Motherboard Replacement: étape 21, image 1 de 1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Motherboard Replacement: étape 22, image 1 de 1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Motherboard Replacement: étape 23, image 1 de 1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Motherboard Replacement: étape 24, image 1 de 1
    • Lift the motherboard off.
9 autres ont terminé cette réparation.
Jed Chen
Membre depuis le 04/01/15
1 796 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 24-6, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 24-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G6
3 membres
5 tutoriels rédigés
5 commentaires
Hi thank you.
winnaingsoe - Réponse
perfekt. Thank you! Had to replace the board because the GPS port was brocken.
Georges Hamlet - Réponse
Hi, thanks for the detailed instructions! I just replaced my main board and the new one did not boot. The battery is charged, but the LCD shows nothing when battery is in and when the power is on. Is that a problem with the replacement main board or does it need to be programmed? I expected it to power up once the power is available.
serget - Réponse
Have you resolved your issue?
Bhaskar vedula -
I get CLOCK with low battery indication . I checked internal battery health and I replaced with new battery on motherboard . Now with new battery in place I see voltage 3.12v and still camera does show CLOCK symbols with low battery. Please let me know if there is hard reset makes default configuration.
Bhaskar vedula - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 35
Total : 5,950
