Aller au contenu principal
Nikon D7000 Shutter Assembly Replacement
Ce dont vous avez besoin
  1. Nikon D7000 Shutter Assembly Replacement, Motherboard: étape 1, image 1 de 1
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Shutter Assembly Replacement: étape 2, image 1 de 1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Shutter Assembly Replacement: étape 3, image 1 de 2 Nikon D7000 Shutter Assembly Replacement: étape 3, image 2 de 2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Shutter Assembly Replacement: étape 4, image 1 de 1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Shutter Assembly Replacement: étape 5, image 1 de 1
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Shutter Assembly Replacement: étape 6, image 1 de 1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Shutter Assembly Replacement: étape 7, image 1 de 1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Shutter Assembly Replacement: étape 8, image 1 de 1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Shutter Assembly Replacement: étape 9, image 1 de 1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Shutter Assembly Replacement: étape 10, image 1 de 1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Shutter Assembly Replacement: étape 11, image 1 de 1
    • Gently pull the SD card cover off.
  12. Nikon D7000 Shutter Assembly Replacement: étape 12, image 1 de 1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Shutter Assembly Replacement: étape 13, image 1 de 1
    • Carefully lift the back case off.
  14. Nikon D7000 Shutter Assembly Replacement: étape 14, image 1 de 3 Nikon D7000 Shutter Assembly Replacement: étape 14, image 2 de 3 Nikon D7000 Shutter Assembly Replacement: étape 14, image 3 de 3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Shutter Assembly Replacement: étape 15, image 1 de 2 Nikon D7000 Shutter Assembly Replacement: étape 15, image 2 de 2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Shutter Assembly Replacement: étape 16, image 1 de 1
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Shutter Assembly Replacement: étape 17, image 1 de 1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Shutter Assembly Replacement: étape 18, image 1 de 1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Shutter Assembly Replacement: étape 19, image 1 de 3 Nikon D7000 Shutter Assembly Replacement: étape 19, image 2 de 3 Nikon D7000 Shutter Assembly Replacement: étape 19, image 3 de 3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Shutter Assembly Replacement: étape 20, image 1 de 2 Nikon D7000 Shutter Assembly Replacement: étape 20, image 2 de 2
  21. Nikon D7000 Shutter Assembly Replacement: étape 21, image 1 de 1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Shutter Assembly Replacement: étape 22, image 1 de 1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Shutter Assembly Replacement: étape 23, image 1 de 1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Shutter Assembly Replacement: étape 24, image 1 de 1
    • Lift the motherboard off.
  25. Nikon D7000 Shutter Assembly Replacement, Tripod Plate: étape 25, image 1 de 1
    • Remove four 6 mm J000 screws securing the tripod plate.
  26. Nikon D7000 Shutter Assembly Replacement: étape 26, image 1 de 1
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
  27. Nikon D7000 Shutter Assembly Replacement, Image Sensor: étape 27, image 1 de 2 Nikon D7000 Shutter Assembly Replacement, Image Sensor: étape 27, image 2 de 2
    • Disconnect black and white speaker cable.
  28. Nikon D7000 Shutter Assembly Replacement: étape 28, image 1 de 1
    • Remove three 6 mm J000 screws securing the image sensor.
  29. Nikon D7000 Shutter Assembly Replacement: étape 29, image 1 de 1
    • Carefully lift the image sensor plate out of the camera.
  30. Nikon D7000 Shutter Assembly Replacement, Shutter Assembly: étape 30, image 1 de 1
    • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
    • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
  31. Nikon D7000 Shutter Assembly Replacement: étape 31, image 1 de 1
    • Remove two 5 mm J000 screws from under the flash.
  32. Nikon D7000 Shutter Assembly Replacement: étape 32, image 1 de 1
    • Remove two 3 mm J000 screws securing the front cover.
  33. Nikon D7000 Shutter Assembly Replacement: étape 33, image 1 de 2 Nikon D7000 Shutter Assembly Replacement: étape 33, image 2 de 2
    • Remove the front cover.
  34. Nikon D7000 Shutter Assembly Replacement: étape 34, image 1 de 1
    • Carefully remove the port cover.
  35. Nikon D7000 Shutter Assembly Replacement: étape 35, image 1 de 1
    • Deroute the microphone cable.
  36. Nikon D7000 Shutter Assembly Replacement: étape 36, image 1 de 1
    • Remove one 4 mm J000 screw from the front.
  37. Nikon D7000 Shutter Assembly Replacement: étape 37, image 1 de 1
    • Remove one 8.5 mm J000 screw from the battery compartment.
  38. Nikon D7000 Shutter Assembly Replacement: étape 38, image 1 de 1
    • Remove the grip carefully.
  39. Nikon D7000 Shutter Assembly Replacement: étape 39, image 1 de 1
    • Remove one 4 mm J000 screw securing the top case (under right strap hook).
  40. Nikon D7000 Shutter Assembly Replacement: étape 40, image 1 de 1
    • Remove one 4 mm J000 screw securing the top case (under left strap hook).
  41. Nikon D7000 Shutter Assembly Replacement: étape 41, image 1 de 1
    • Remove the sticker covering the diopter adjust screw.
  42. Nikon D7000 Shutter Assembly Replacement: étape 42, image 1 de 1
    • Remove one 8.0 mm J000 screw.
    • Remove the Diopeter Adjust.
  43. Nikon D7000 Shutter Assembly Replacement: étape 43, image 1 de 1
    • Remove the top case.
  44. Nikon D7000 Shutter Assembly Replacement: étape 44, image 1 de 1
    • Remove the Black, Yellow, Green cable from the top case board.
  45. Nikon D7000 Shutter Assembly Replacement: étape 45, image 1 de 3 Nikon D7000 Shutter Assembly Replacement: étape 45, image 2 de 3 Nikon D7000 Shutter Assembly Replacement: étape 45, image 3 de 3
    • Remove two 6.5 mm J000 screws securing the viewfinder.
    • Remove the viewfinder cover.
  46. Nikon D7000 Shutter Assembly Replacement: étape 46, image 1 de 1
    • Remove one 3 mm J000 screw from the bottom left side of the camera.
  47. Nikon D7000 Shutter Assembly Replacement: étape 47, image 1 de 1
    • Remove two 6 mm J000 screws from the left of the shutter.
  48. Nikon D7000 Shutter Assembly Replacement: étape 48, image 1 de 1
    • Remove two 6.5 mm J000 screws from beneath the lens mount.
  49. Nikon D7000 Shutter Assembly Replacement: étape 49, image 1 de 1
    • Remove two screws from just below and to the sides of the viewfinder.
  50. Nikon D7000 Shutter Assembly Replacement: étape 50, image 1 de 1
    • Remove one 5 mm J000 screw from the top right of the camera.
  51. Nikon D7000 Shutter Assembly Replacement: étape 51, image 1 de 1
    • Carefully peel back ribbon cable on the bottom left of camera.
  52. Nikon D7000 Shutter Assembly Replacement: étape 52, image 1 de 2 Nikon D7000 Shutter Assembly Replacement: étape 52, image 2 de 2
    • Remove the left front ribbon cable from top right of circuit board.
  53. Nikon D7000 Shutter Assembly Replacement: étape 53, image 1 de 1
    • Remove all three wire connectors.
  54. Nikon D7000 Shutter Assembly Replacement: étape 54, image 1 de 1
    • Separate the shutter assembly from the camera body.
34 autres ont terminé cette réparation.
Steven Castaneda
Membre depuis le 04/02/15
676 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 24-6, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 24-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G6
3 membres
5 tutoriels rédigés
10 commentaires
Use a #00 Philips, not a #0, or you'll strip the screws. Also, there are two or three screws connecting the shutter assembly to the camera body, and its contacts are soldered on. So you need a soldering iron for the last step.
Michael Duncan - Réponse
im gonna be trying this soon , how long did it take and how difficult is it ,,,
Dean Wilkinson - Réponse
Guide not completed. Last step only shows removal of mirror box. Shutter assembly replacement not
Ziyang - Réponse
Regardless of possibly a few missing steps, this is a great lesson of how to deal with shutter replacement on my own. Hats off !!
Mateusz Witek - Réponse
How to reassemble diopter adjustment?
Jerome - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 65
Total : 18,981
