Introduction
This guide will show you how to replace the volume slider of your Nintendo 2DS. The volume slider may not break often but if you find yourself with a slider that is stuck in place or you're unable to control the level of volume, this guide may help.
Before beginning this repair, turn off the device.
Ce dont vous avez besoin
Turn the 2DS over so that the backside is facing upwards.
Identify the two Phillips #00 screws on the upper rear panel.
Loosen the two screws on the upper back panel using a Phillips #00 screwdriver.
Use a spudger to pry the upper back panel off, starting at the indent at the center top of the panel.
Use a spudger and work your way around the perimeter to release the clips and then lift the panel off.
Use a spudger to pry the back case off by working around the perimeter of the device, starting from the bottom of the 2DS.
Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the camera cable.
Use your spudger to gently slide the cable out of the connector.
Remove the back case.
