Aller au contenu principal
Nintendo 64 Power Supply Power Cable Replacement
Ce dont vous avez besoin
  1. Nintendo 64 Power Supply Power Cable Replacement, Power Cable: étape 1, image 1 de 2 Nintendo 64 Power Supply Power Cable Replacement, Power Cable: étape 1, image 2 de 2
    • Unscrew the 2 security screws on the corners of the case using a 4.5mm security bit driver.
  2. Nintendo 64 Power Supply Power Cable Replacement: étape 2, image 1 de 2 Nintendo 64 Power Supply Power Cable Replacement: étape 2, image 2 de 2
    • Remove the cover by gently prying from the side with the screws.
    • There are two clips that will let loose on the opposite side as you pry.
    • This will expose the circuit board needed for the repair.
  3. Nintendo 64 Power Supply Power Cable Replacement: étape 3, image 1 de 1
    • Remove the circuit board from the other half of the plastic case by pulling it straight out
    • There may be some adhesive holding it on to the plastic
  4. Nintendo 64 Power Supply Power Cable Replacement: étape 4, image 1 de 2 Nintendo 64 Power Supply Power Cable Replacement: étape 4, image 2 de 2
    • Remove the original power leads by melting the solder using a soldering gun.
    • You will need to pull the wire from the backside but use caution to not touch any metallic parts as they will be hot.
    • If you do not know how to solder, read this Soldering Skills guide on ifixit.
  5. Nintendo 64 Power Supply Power Cable Replacement: étape 5, image 1 de 3 Nintendo 64 Power Supply Power Cable Replacement: étape 5, image 2 de 3 Nintendo 64 Power Supply Power Cable Replacement: étape 5, image 3 de 3
    • Clear the boot by pulling the copper wires out with pliers.
    • This will leave the wire sheathing which can then be cut flush with sharp knife.
    • Tip: Sand cut the end with fine grit sandpaper if desired.
  6. Nintendo 64 Power Supply Power Cable Replacement: étape 6, image 1 de 2 Nintendo 64 Power Supply Power Cable Replacement: étape 6, image 2 de 2
    • Use the drill to drill out the wire sheathing.
    • Drill each hole twice.
    • First, use a 5/64th drill bit. Then, use a larger 1/8th drill bit to finish.
    • The holes should be clean and free of debris once complete.
  7. Nintendo 64 Power Supply Power Cable Replacement: étape 7, image 1 de 3 Nintendo 64 Power Supply Power Cable Replacement: étape 7, image 2 de 3 Nintendo 64 Power Supply Power Cable Replacement: étape 7, image 3 de 3
    • Feed the new cable through the boot .
    • Glue it in place by applying glue to the wire (close to the desired location of the boot) and sliding the boot into place.
    • Be sure the exposed wire length is close to the original.
  8. Nintendo 64 Power Supply Power Cable Replacement: étape 8, image 1 de 2 Nintendo 64 Power Supply Power Cable Replacement: étape 8, image 2 de 2
    • Align the wires with their original positions on the circuit board.
    • Looking at the component side of the board, the hot side is marked with an L for load and the neutral is marked with an N.
    • The neutral wire goes here, the hole closer to the center of the circuit board.
    • The hot wire goes here, closer to the outside.
    • The neutral wire can be identified by the wider prong on the plug end of the cord.
  9. Nintendo 64 Power Supply Power Cable Replacement: étape 9, image 1 de 2 Nintendo 64 Power Supply Power Cable Replacement: étape 9, image 2 de 2
    • Solder the new wires onto the circuit board.
  10. Nintendo 64 Power Supply Power Cable Replacement: étape 10, image 1 de 2 Nintendo 64 Power Supply Power Cable Replacement: étape 10, image 2 de 2
    • Use a flexible glue to put on the original adhesive.
    • Insert the board, aligning the boot with the slot.
To reassemble your device, follow steps 1-3 in reverse order.
Brandon Clausen
Membre depuis le 06/23/23
181 Réputation
1 tutoriel rédigé
Équipe
ENGL 3603 Group 4 Membre de l'équipe ENGL 3603 Group 4
Local Repair Groups
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 82
Total : 714
