Introduction
How to replace the power cable on an N64 power supply.
Ce dont vous avez besoin
Unscrew the 2 security screws on the corners of the case using a 4.5mm security bit driver.
Align the wires with their original positions on the circuit board.
Looking at the component side of the board, the hot side is marked with an L for load and the neutral is marked with an N.
The neutral wire goes here, the hole closer to the center of the circuit board.
The hot wire goes here, closer to the outside.
To reassemble your device, follow steps 1-3 in reverse order.
