Introduction
This guide will help you install the C Stick. The C Stick is the yellow joystick. This guide should be helpful if the C Stick has gone rogue.
Ce dont vous avez besoin
Place the controller (buttons down) on a solid surface.
Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
Use your fingers to grab the two sides of the connector and gently wiggle out.
13 autres ont terminé cette réparation.
2 commentaires
This doesnt help by c stick is broken and i need help. Up and down work just fine on it, but it doesnt rgister left and right. Anybody have any help?
I did a mod on it and it worked fine until then but its really weird that left and right arent working but up and down are i couldve accidentally got hot glue in there... Any way to buy an entirely new c stick unit?
