Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nokia Lumia 2520 Cameras Replacement
Ce dont vous avez besoin
  1. Nokia Lumia 2520 Cameras  Replacement, Display Assembly: étape 1, image 1 de 1
    • Apply heat pad to each side of the device.
    • When using any heat pad please use some form of padded gloves so you don't burn you fingers.
    • Microwave the pad for 30 seconds so an ample amount of heat is given on all four sides. Do not microwave more than once every two minutes.
    Demander à FixBot
    Ajouter un commentaire
  2. Nokia Lumia 2520 Cameras  Replacement: étape 2, image 1 de 3 Nokia Lumia 2520 Cameras  Replacement: étape 2, image 2 de 3 Nokia Lumia 2520 Cameras  Replacement: étape 2, image 3 de 3
    • Insert the pick between the glass to separate the glass from the device. You can also use the suction cups to help lift the glass.
    • When pulling the screen off the chassis, be careful not to cut the ribbon cable that connects the screen to the logic board.
    • Take your time to pry open the screen from the chassis as you can easily break the screen or crack it.
    Demander à FixBot
  3. Nokia Lumia 2520 Cameras  Replacement: étape 3, image 1 de 2 Nokia Lumia 2520 Cameras  Replacement: étape 3, image 2 de 2
    • Pull the ribbon cable out from the connection port on the board.
    • Move on the step 4 to remove the ribbon connection from the screen.
    Demander à FixBot
  4. Nokia Lumia 2520 Cameras  Replacement: étape 4, image 1 de 3 Nokia Lumia 2520 Cameras  Replacement: étape 4, image 2 de 3 Nokia Lumia 2520 Cameras  Replacement: étape 4, image 3 de 3
    • Use the plastic pry tool to remove both of the connections.
    Demander à FixBot
  5. Nokia Lumia 2520 Cameras  Replacement: étape 5, image 1 de 1
    • Set aside the screen and the display assembly for repair.
    Demander à FixBot
  6. Nokia Lumia 2520 Cameras  Replacement, Battery: étape 6, image 1 de 3 Nokia Lumia 2520 Cameras  Replacement, Battery: étape 6, image 2 de 3 Nokia Lumia 2520 Cameras  Replacement, Battery: étape 6, image 3 de 3
    • Before removing the battery from the device be sure not to puncture the battery. Since the battery is a form of acid.
    • Using a plastic pry tool is better than a metal tool when working with wire and soft case battery case.
    • Use a plastic pry tool to remove the battery connector from the logic board.
    Demander à FixBot
  7. Nokia Lumia 2520 Cameras  Replacement: étape 7, image 1 de 2 Nokia Lumia 2520 Cameras  Replacement: étape 7, image 2 de 2
    • Remove the ribbon located over the battery.
    Demander à FixBot
  8. Nokia Lumia 2520 Cameras  Replacement: étape 8, image 1 de 1
    • Theres four screws that attach the battery to the chassis. Use a PH0 Phillips head screwdriver to loosen the screw.
    • Since the tool using is sharp please use with caution, so that you don't puncture the battery.
    Demander à FixBot
  9. Nokia Lumia 2520 Cameras  Replacement: étape 9, image 1 de 3 Nokia Lumia 2520 Cameras  Replacement: étape 9, image 2 de 3 Nokia Lumia 2520 Cameras  Replacement: étape 9, image 3 de 3
    • Take a plastic pry to to pry out the battery from its casing.
    • The bottom of the battery has adhesive to hold the battery in place. So using enough pressure to pry the battery is ok .
    • Using two tool different plastic pry to can help give you leverage on areas that are hard to get up.
    Demander à FixBot
  10. Nokia Lumia 2520 Cameras  Replacement, Cameras: étape 10, image 1 de 3 Nokia Lumia 2520 Cameras  Replacement, Cameras: étape 10, image 2 de 3 Nokia Lumia 2520 Cameras  Replacement, Cameras: étape 10, image 3 de 3
    • Take a PH0 Phillps head screw bit to take the screw out.
    • Take a pry tool and disconnect the ribbon cabe from the logic board
    • Then use a plastic pry tool and take out the front facing camera out of its housing.
    • The front facing camera is clued on so use some force to pry it off.
    Demander à FixBot
  11. Nokia Lumia 2520 Cameras  Replacement: étape 11, image 1 de 3 Nokia Lumia 2520 Cameras  Replacement: étape 11, image 2 de 3 Nokia Lumia 2520 Cameras  Replacement: étape 11, image 3 de 3
    • Locate the rear facing camera. which is located on the top right side of the case.
    • Take a plastic pry tool to pill the tape and camera from its housing.
    Demander à FixBot
  12. Nokia Lumia 2520 Cameras  Replacement: étape 12, image 1 de 3 Nokia Lumia 2520 Cameras  Replacement: étape 12, image 2 de 3 Nokia Lumia 2520 Cameras  Replacement: étape 12, image 3 de 3
    • Take the pry tool and remove the ribbon cable from the logic board.
    Demander à FixBot
Degan Berhe
Membre depuis le 08/29/18
614 Réputation
4 tutoriels rédigés
Équipe
Gateway, Team S1-G4, Luster Fall 2018 Membre de l'équipe Gateway, Team S1-G4, Luster Fall 2018
GCC-LUSTER-F18S1G4
5 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 19
Total : 513
