Aller au contenu principal
Nook Simple Touch with GlowLight Battery Replacement
Ce dont vous avez besoin
  1. Nook Simple Touch with GlowLight Battery Replacement, Power Button: étape 1, image 1 de 1
    • Place the Nook with the screen facing down.
  2. Nook Simple Touch with GlowLight Battery Replacement: étape 2, image 1 de 1
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
  3. Nook Simple Touch with GlowLight Battery Replacement: étape 3, image 1 de 1
    • Using your fingers, gently remove the power button.
  4. Nook Simple Touch with GlowLight Battery Replacement, Back Cover: étape 4, image 1 de 1
    • Remove the single screw using a T4 Torx screwdriver.
  5. Nook Simple Touch with GlowLight Battery Replacement: étape 5, image 1 de 1
    • Slide the back cover down towards you in the direction of the charging port.
  6. Nook Simple Touch with GlowLight Battery Replacement, Battery: étape 6, image 1 de 2 Nook Simple Touch with GlowLight Battery Replacement, Battery: étape 6, image 2 de 2
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
Sean Blevins
Membre depuis le 03/01/23
73 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 13
30 derniers jours : 56
Total : 456
