Aller au contenu principal
Nook Simple Touch with GlowLight Charging Port Replacement
Ce dont vous avez besoin
  1. Nook Simple Touch with GlowLight Charging Port Replacement, Power Button: étape 1, image 1 de 1
    • Place the Nook with the screen facing down.
  2. Nook Simple Touch with GlowLight Charging Port Replacement: étape 2, image 1 de 1
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
  3. Nook Simple Touch with GlowLight Charging Port Replacement: étape 3, image 1 de 1
    • Using your fingers, gently remove the power button.
  4. Nook Simple Touch with GlowLight Charging Port Replacement, Back Cover: étape 4, image 1 de 1
    • Remove the single screw using a T4 Torx screwdriver.
  5. Nook Simple Touch with GlowLight Charging Port Replacement: étape 5, image 1 de 1
    • Slide the back cover down towards you in the direction of the charging port.
  6. Nook Simple Touch with GlowLight Charging Port Replacement, Battery: étape 6, image 1 de 2 Nook Simple Touch with GlowLight Charging Port Replacement, Battery: étape 6, image 2 de 2
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
  7. Nook Simple Touch with GlowLight Charging Port Replacement, Motherboard: étape 7, image 1 de 1
    • Remove eleven screws from the motherboard using the T4 screwdriver.
  8. Nook Simple Touch with GlowLight Charging Port Replacement: étape 8, image 1 de 3 Nook Simple Touch with GlowLight Charging Port Replacement: étape 8, image 2 de 3 Nook Simple Touch with GlowLight Charging Port Replacement: étape 8, image 3 de 3
    • Disconnect the orange ribbon cable from the motherboard.
    • Using your fingers, gently lift the motherboard from the display.
  9. Nook Simple Touch with GlowLight Charging Port Replacement, Charging Port: étape 9, image 1 de 1
    • Flip the motherboard over and locate the charging port.
  10. Nook Simple Touch with GlowLight Charging Port Replacement: étape 10, image 1 de 1
    • Using a soldering iron, disconnect the charging port from the motherboard.
    • Use the soldering iron to attach the new charging port to the motherboard.
    • Be careful with the soldering iron - it is very hot and can damage your hands or the device.
Sydney Segear
Membre depuis le 03/01/23
401 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 9
Total : 122
