Aller au contenu principal
Nook Simple Touch with GlowLight Screen Replacement
Ce dont vous avez besoin
  1. Nook Simple Touch with GlowLight Screen Replacement, Power Button: étape 1, image 1 de 1
    • Place the Nook with the screen facing down.
  2. Nook Simple Touch with GlowLight Screen Replacement: étape 2, image 1 de 1
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
  3. Nook Simple Touch with GlowLight Screen Replacement: étape 3, image 1 de 1
    • Using your fingers, gently remove the power button.
  4. Nook Simple Touch with GlowLight Screen Replacement, Back Cover: étape 4, image 1 de 1
    • Remove the single screw using a T4 Torx screwdriver.
  5. Nook Simple Touch with GlowLight Screen Replacement: étape 5, image 1 de 1
    • Slide the back cover down towards you in the direction of the charging port.
  6. Nook Simple Touch with GlowLight Screen Replacement, Battery: étape 6, image 1 de 2 Nook Simple Touch with GlowLight Screen Replacement, Battery: étape 6, image 2 de 2
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
  7. Nook Simple Touch with GlowLight Screen Replacement, Motherboard: étape 7, image 1 de 1
    • Remove eleven screws from the motherboard using the T4 screwdriver.
  8. Nook Simple Touch with GlowLight Screen Replacement: étape 8, image 1 de 3 Nook Simple Touch with GlowLight Screen Replacement: étape 8, image 2 de 3 Nook Simple Touch with GlowLight Screen Replacement: étape 8, image 3 de 3
    • Disconnect the orange ribbon cable from the motherboard.
    • Using your fingers, gently lift the motherboard from the display.
  9. Nook Simple Touch with GlowLight Screen Replacement, Screen: étape 9, image 1 de 2 Nook Simple Touch with GlowLight Screen Replacement, Screen: étape 9, image 2 de 2
    • Insert the iFixit opening tool between the display and the front case.
    • Gently move to iFixit opening tool around the perimeter to release the set of tape strips.
  10. Nook Simple Touch with GlowLight Screen Replacement: étape 10, image 1 de 2 Nook Simple Touch with GlowLight Screen Replacement: étape 10, image 2 de 2
    • Turn the display over. Pry the display bezel from the display assembly with the iFixit opening tool.
Sydney Segear
Membre depuis le 03/01/23
401 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 19
30 derniers jours : 45
Total : 440
