Introduction
Use this guide to remove the frame from the screen on your OLPC XO 4.0 Touch.
Pièces
Aucune pièce nécessaire.
  1. Turn the laptop upside-down, with the handle facing away from you.
    • Turn the laptop upside-down, with the handle facing away from you.
  2. Pull the lock tabs towards the green outer edges of the laptop. Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. Lift up on the middle of the battery to remove it from the device. Lift up on the middle of the battery to remove it from the device.
    • Lift up on the middle of the battery to remove it from the device.
  4. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Vous avez déjà réparé quelque chose ? Vous êtes un génie.
    Partagez votre réparation avec le hashtag #ImAGenius
    Nous sommes tous des génies
  5. Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side. Rotate the screen 180° and remove the other two screws. You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  6. Remove the green side panel by pressing down on the small green button on the top and sliding the panel up. Repeat the step above for the panel on the other side. Repeat the step above for the panel on the other side.
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  7. Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  8. Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame. Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
Ji Kim
Membre depuis le 25/01/2013
18 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 3-29, Amido Winter 2013 Membre de l'équipe Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
4 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 109
