Aller au contenu principal
Opening the Siemens Surpresso Compact
Ce dont vous avez besoin
  1. Opening the Siemens Surpresso Compact, Opening the Siemens Surpresso Compact: étape 1, image 1 de 1
    • Unplug your coffee maker!
    • Remove the water container, the brew group and the drip tray with pomace container.
    • Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
    • Depending on the model, additional sensors with cables may be installed on the top and side panels. You have to remove these before you can completely remove the housing parts.
  2. Opening the Siemens Surpresso Compact: étape 2, image 1 de 1
    • Remove the two Torx T10 screws on the top.
  3. Opening the Siemens Surpresso Compact: étape 3, image 1 de 2 Opening the Siemens Surpresso Compact: étape 3, image 2 de 2
    • Remove seven T10 Torx screws on the back.
    • The two screws at the bottom of the front can remain.
  4. Opening the Siemens Surpresso Compact: étape 4, image 1 de 2 Opening the Siemens Surpresso Compact: étape 4, image 2 de 2
    • Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
    • Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
    • Lift the top off.
    • On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
  5. Opening the Siemens Surpresso Compact: étape 5, image 1 de 2 Opening the Siemens Surpresso Compact: étape 5, image 2 de 2
    • Slide the side section of the brewing unit about 2 cm to the rear. This sometimes gets stuck and may require some force to remove.
    • Remove the two tabs from the power switch.
    • Take off the side panel with the brew group.
  6. Opening the Siemens Surpresso Compact: étape 6, image 1 de 1
    • Do the same with the panel on the other side.
    • To remove the water tank hose simply pull it of the pump.
    • Remove the side panel.
To reassemble your device, follow the steps in reverse order.
15 autres ont terminé cette réparation.
Merci à ces traducteurs :
de en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
VauWeh
Membre depuis le 10/19/15
204 141 Réputation
246 tutoriels rédigés
Équipe
Repair is War on Entropy Membre de l'équipe Repair is War on Entropy
Community
25 membres
1 129 tutoriels rédigés
3 commentaires
Sehr gut beschrieben und bebildert, danach kann man gut arbeiten, Danke.
h.kornetzki - Réponse
Wie bekomme ich den vorderen Gehäusedeckel ab? Ich muss den Dampfschalter tauschen.
sabine.gorski - Réponse
Hab ich noch nie gemacht. Sicher muss der Auslauf weg: Siemens Surpresso Compact Kaffeeauslaufverteiler austauschen, suche dann die Schrauben und Rasten. Gutes Gelingen, wir würden uns freuen, wenn du das für iFixit dokumentierst!
VauWeh -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 73
Total : 7,423
