Aller au contenu principal
Optoma HD20 Fan Replacement
Ce dont vous avez besoin
  1. Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: étape 1, image 1 de 2 Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: étape 1, image 2 de 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    The pictures don't really do justice to how hard it is to pop the focal cap off. One actually has to pull pretty hard, I was afraid of breaking something, but it all worked out.
    eislerzoltan - Réponse
    you da best <3 ty for comment
    Weyland Chiang - Réponse
  2. Optoma HD20 Fan Replacement: étape 2, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Fan Replacement: étape 3, image 1 de 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Fan Replacement: étape 4, image 1 de 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    The black part is the clip that lifts up. Then gently tug on the cable.
    The instructions are out of order here.
    dlwalter - Réponse
    Wish I had read your comment before struggling with it for what seemed like hours.
    eislerzoltan -
    Any advice for if you rip that ribbon?
    robby_g - Réponse
    Yes… Advice for when you go into this BEFORE consulting the internet and accidentally RIP it out?
    Mathew Amaral -
    I ripped the ribbon. Where can I find it’s replacement?
    Rohit Ghatol - Réponse
  5. Optoma HD20 Fan Replacement, Fan: étape 5, image 1 de 1
    • Peel off the tape that is holding the metal casing down.
  6. Optoma HD20 Fan Replacement: étape 6, image 1 de 2 Optoma HD20 Fan Replacement: étape 6, image 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the nine 4.5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the three 2.5 mm screws. This will allow you to remove the metal casing.
    On mine, the bottom left red screw pictured doesn't hold the case (only circuit board), and there is an additional screw top middle, not pictured here, so still 9 total)
    Gyrovague - Réponse
  7. Optoma HD20 Fan Replacement: étape 7, image 1 de 1
    • Remove the metal casing by lifting it up off of the circuit board.
  8. Optoma HD20 Fan Replacement: étape 8, image 1 de 1
    • Unplug the six wires stemming from the circuit board.
  9. Optoma HD20 Fan Replacement: étape 9, image 1 de 1
    • Use a Philips #1 screwdriver to remove the four 4.5 mm screws
    Mine doesn't have the rightmost screw pictured here, instead a screw in the corner of the board just out of top right of photo.
    Gyrovague - Réponse
  10. Optoma HD20 Fan Replacement: étape 10, image 1 de 1
    • Remove the three 4.5 mm screws using the Philips #1 screwdriver.
    The screw between the analogue inputs is longer and coarser pitch on my unit than the other two screws.
    Gyrovague - Réponse
  11. Optoma HD20 Fan Replacement: étape 11, image 1 de 1
    • Remove the two 4.5 mm screws located on either side of the VGA/SCART port using a 5 mm nut driver. This will further release the plastic backing from the motherboard.
  12. Optoma HD20 Fan Replacement: étape 12, image 1 de 1
    • Slightly rotate the motherboard clockwise. This will prevent ports from getting caught on the plastic backing.
    • Lift the plastic backing to remove it.
    Note, board has a connector on the lens side, connecting to a vertical board behind the lens (probably DMD board). This is especially important to remember when reassembling!
    Gyrovague - Réponse
  13. Optoma HD20 Fan Replacement: étape 13, image 1 de 1
    • Ensure all screws are removed
    • Lift up the motherboard and take out the metal container beneath it.
    • Do this very carefully as there is still one cable attached.
  14. Optoma HD20 Fan Replacement: étape 14, image 1 de 1
    • Unplug the white connector underneath the right side of the circuit board.
    • To remove, pinch both sides of the connector and pull it away from the circuit board.
  15. Optoma HD20 Fan Replacement: étape 15, image 1 de 2 Optoma HD20 Fan Replacement: étape 15, image 2 de 2
    • Use a Phillips #1 screwdriver to remove four 5 mm screws. This will release the fan.
    Not sure if it’s necessary to remove any of these screws. None appear to actually secure the fan itself.
    John Schroeder - Réponse
  16. Optoma HD20 Fan Replacement: étape 16, image 1 de 2 Optoma HD20 Fan Replacement: étape 16, image 2 de 2
    • Pull the fan away from the metal housing unit.
    • Gently lift the fan up and out of the device. The fan is now removed.
    Not mentioned here is that you pretty much need to bend the cardboard airflow director thing out the way, then sortof twist the fan out (can't pull backwards because the large heatsink is in the way).
    Gyrovague - Réponse
    Putting the new fan in is quite tricky. I managed eventually, but it might be much easier to remove the large heatsink. Not sure how safe that is though.
    Gyrovague - Réponse
    I replaced the larger lamp fan (KDE1285PTV1) after this, by removing the entire metal cage around the lamp (5 screws), this would have made replacing the small fan (GB1245PKVX-8) trivial, so I highly recommend doing it that way!
    Gyrovague - Réponse
    My fan had a rubber boot around it (not seen or mentioned here), as well as a bit of foam tape around the front edge (as seen in pic #2). My replacement fan did not have this tape, so I substituted some masking tape. Not sure of its purpose or whether its absence will be a problem. Still piecing the thing back together.
    Removal and replacement of the fan was indeed challenging. I used a couple popsicle sticks to help get the boot back over it.
6 autres ont terminé cette réparation.
Trever
Membre depuis le 01/22/15
1 264 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 21-23, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 membres
6 tutoriels rédigés
6 Guide Comments
Very nice set of instructions! Excellent images and identification of items to remove. Thank you!
Graveyard Workshop - Réponse
Do you know where to get this fan for replacement? Having trouble finding a parts list.
Sterling Grogg - Réponse
Small fan is GB1245PKVX-8, large fan is KDE1285PTV1
Gyrovague -
I am trying to determine if the fan works or not. Should the fan come on when there is no bulb in the projector? I removed the bulb when it burned up and I am not sure whether it was due to a failed fan or simply the bulb.
merrill277 - Réponse
Amazing! Thank you!!! Took a bit of effort to get the fan but in the end it worked like a charm!! Thank you for saving money!!!!
Mike Popov - Réponse
So I have an HD25, which is nearly identical. However, I ordered a replacement GB1245PKVX-8 fan and the cable for it is at least an inch shorter, making it impossible to reach the main board. Any ideas here?
C Ruad - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 47
Total : 13,362
