Introduction
This replacement guide is for the primary charging base for the device. This base is where the answering machine is housed, and where the TEL line is connected. If the symptoms of your device indicate that you need to replace one of the components inside of the charging base, or you just need to give the front panel of the base a face lift with a newer piece, this is the guide you'll want to follow.
Ce dont vous avez besoin
To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
