Aller au contenu principal
Philips Satinelle Disassembly
Ce dont vous avez besoin
  1. Philips Satinelle Disassembly, Philips Satinelle Disassembly: étape 1, image 1 de 2 Philips Satinelle Disassembly, Philips Satinelle Disassembly: étape 1, image 2 de 2
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. Philips Satinelle Disassembly: étape 2, image 1 de 3 Philips Satinelle Disassembly: étape 2, image 2 de 3 Philips Satinelle Disassembly: étape 2, image 3 de 3
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. Philips Satinelle Disassembly: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • The left side will swing down.
    • Remove the Tweezers.
  4. Philips Satinelle Disassembly: étape 4, image 1 de 3 Philips Satinelle Disassembly: étape 4, image 2 de 3 Philips Satinelle Disassembly: étape 4, image 3 de 3
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  5. Philips Satinelle Disassembly: étape 5, image 1 de 3 Philips Satinelle Disassembly: étape 5, image 2 de 3 Philips Satinelle Disassembly: étape 5, image 3 de 3
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  6. Philips Satinelle Disassembly: étape 6, image 1 de 3 Philips Satinelle Disassembly: étape 6, image 2 de 3 Philips Satinelle Disassembly: étape 6, image 3 de 3
    • Use a spudger to pry the gear housing unit from the base.
  7. Philips Satinelle Disassembly: étape 7, image 1 de 3 Philips Satinelle Disassembly: étape 7, image 2 de 3 Philips Satinelle Disassembly: étape 7, image 3 de 3
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
6 autres ont terminé cette réparation.
Nathan Christian
Membre depuis le 11/11/17
505 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S5-G5, Wilson Fall 2017 Membre de l'équipe IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
3 membres
4 tutoriels rédigés
6 commentaires
can we open the lower part which holds the motor and gear..
actualy the gear which holds the motor is gone bad i think.. so i want to replace it ..
can this be fixed..??
Md Wasim Anwar - Réponse
Same here .. wanted to open the bottom part which holds a longish gear .. the top gear fits in a very small portion of the bottom long gear so the long gear has worn out in just that area
S Ahooja - Réponse
similar here, wanted to open the lower part where the cable goes in. the cable is broken at the entry.
frankgerling - Réponse
Thank you for this great tutorial. It really helps!
Can you please give us the dimensions for the gear’s teeth in step 7 and the corresponding gear in step 2 in the Philips Satinelle Motor Replacement tutorial? I can 3D print the gears, but I can’t find the dimensions online and the gears are simply to eroded to be able to measure them.
Albert Westhoff - Réponse
honestly, thank you so much from the bottom of my heart. my epilator had two threads stuck in it that I couldn't reach and it was doing a *!&*^#% $@$*!& job removing hair but then I found this guide. you saved me from having to unnecessarily buy another epilator. mine's as good as new and the best part is that I now know how to open it up again in case I have to do it once more. thanks man. ?
Sanjana T - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 25
30 derniers jours : 83
Total : 8,243
