Introduction
This guide will walk you through step-by-step on how to properly remove and install the clock battery in the PlayStation 2 Slimline.
Pièces
Aucune pièce spécifiée.
Turn off the PlayStation 2 (or PS2) and carefully unplug from the power source. Check to see there are no discs inside the console before flipping the game system upside-down.
Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
3 autre(s) ont terminé cette réparation.
Un commentaire
These instructions take for granted how the battery itself should be replaced. I imagine you reconnect the contact with the red wire to the positive side of the CR2032 battery and the contact for the black wire to the negative and wrap electrical tape around the entire thing BEFORE reconnecting it and then following these instructions in reverse order.
