Introduction
Use this guide to replace your heat sink. It is essential to apply a new layer of thermal paste during reassembly.
Ce dont vous avez besoin
Turn the PS3 over and lay it on its backside.
Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
Pull the AC-In cables upward to remove the AC inlet from the lower case.
Disconnect the DC-In and Blu-ray power cables from the motherboard.
Remove the two 9.5 mm Phillips screws securing the fan to the heat sink.
42 autres ont terminé cette réparation.
7 commentaires
Thanks for this guide
Hi, is the heatsink that makes contact with the cpu die aluminium? I think I might have repasted it with liquid metal… Thanks!
