Aller au contenu principal
Pour réparer ensemble - Je crée un compte
PlayStation 4 Optical Drive Replacement
Ce dont vous avez besoin
    1. PlayStation 4 Optical Drive Replacement, Flip over the PS4: étape 1, image 1 de 1
      • Flip the PS4 upside-down with the back side facing towards you.
      Demander à FixBot
      Ajouter un commentaire
    2. PlayStation 4 Optical Drive Replacement, Remove the warranty stickers: étape 2, image 1 de 3 PlayStation 4 Optical Drive Replacement, Remove the warranty stickers: étape 2, image 2 de 3 PlayStation 4 Optical Drive Replacement, Remove the warranty stickers: étape 2, image 3 de 3
      Outil utilisé dans cette étape :
      • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
      Demander à FixBot
    3. PlayStation 4 Optical Drive Replacement, Remove the plastic screw covers: étape 3, image 1 de 2 PlayStation 4 Optical Drive Replacement, Remove the plastic screw covers: étape 3, image 2 de 2
      • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
      Demander à FixBot
    4. PlayStation 4 Optical Drive Replacement, Remove the rear case screws: étape 4, image 1 de 2 PlayStation 4 Optical Drive Replacement, Remove the rear case screws: étape 4, image 2 de 2
      • Remove the four 7.2 mm T8 Torx security screws on the back of the PS4.
      Demander à FixBot
    5. PlayStation 4 Optical Drive Replacement, Remove the lower case: étape 5, image 1 de 2 PlayStation 4 Optical Drive Replacement, Remove the lower case: étape 5, image 2 de 2
      • Use your thumbs to lift the lower case up and off the PS4.
      • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
      Demander à FixBot
    6. PlayStation 4 Optical Drive Replacement: étape 6, image 1 de 2 PlayStation 4 Optical Drive Replacement: étape 6, image 2 de 2
      • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
      • If your connector feels stuck, use a spudger to gently pry the connector out.
      Demander à FixBot
    1. PlayStation 4 Optical Drive Replacement, Remove the power supply unit: étape 7, image 1 de 2 PlayStation 4 Optical Drive Replacement, Remove the power supply unit: étape 7, image 2 de 2
      • Remove three 9.7 mm-long TR8 Torx security screws.
      • Remove two 41 mm-long Phillips screws and brackets.
      Demander à FixBot
    2. PlayStation 4 Optical Drive Replacement: étape 8, image 1 de 3 PlayStation 4 Optical Drive Replacement: étape 8, image 2 de 3 PlayStation 4 Optical Drive Replacement: étape 8, image 3 de 3
      • Lift the power supply straight up and out of the PS4.
      • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
      • During reassembly, ensure the prongs are aligned, then press the power supply into place.
      Demander à FixBot
    1. PlayStation 4 Optical Drive Replacement, Remove the Wi-Fi antenna: étape 9, image 1 de 2 PlayStation 4 Optical Drive Replacement, Remove the Wi-Fi antenna: étape 9, image 2 de 2
      • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
      Demander à FixBot
    2. PlayStation 4 Optical Drive Replacement: étape 10, image 1 de 3 PlayStation 4 Optical Drive Replacement: étape 10, image 2 de 3 PlayStation 4 Optical Drive Replacement: étape 10, image 3 de 3
      • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
      Demander à FixBot
    3. PlayStation 4 Optical Drive Replacement: étape 11, image 1 de 3 PlayStation 4 Optical Drive Replacement: étape 11, image 2 de 3 PlayStation 4 Optical Drive Replacement: étape 11, image 3 de 3
      • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
      Demander à FixBot
    4. PlayStation 4 Optical Drive Replacement: étape 12, image 1 de 2 PlayStation 4 Optical Drive Replacement: étape 12, image 2 de 2
      • Remove the 9.7 mm Torx security screw securing the antenna.
      Demander à FixBot
    5. PlayStation 4 Optical Drive Replacement: étape 13, image 1 de 2 PlayStation 4 Optical Drive Replacement: étape 13, image 2 de 2
      • Remove the Wi-Fi antenna.
      Demander à FixBot
    1. PlayStation 4 Optical Drive Replacement, Disconnect the optical drive: étape 14, image 1 de 3 PlayStation 4 Optical Drive Replacement, Disconnect the optical drive: étape 14, image 2 de 3 PlayStation 4 Optical Drive Replacement, Disconnect the optical drive: étape 14, image 3 de 3
      • Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive.
      • Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab.
      • You do not need to press the metal lever when inserting the ribbon cable back in. You will hear a click once it is fully inserted.
      Demander à FixBot
    2. PlayStation 4 Optical Drive Replacement: étape 15, image 1 de 3 PlayStation 4 Optical Drive Replacement: étape 15, image 2 de 3 PlayStation 4 Optical Drive Replacement: étape 15, image 3 de 3
      • Use your fingernail to press down the metal release lever for the ribbon cable connected to the motherboard.
      • Set the ribbon cable aside for reassembly.
      Demander à FixBot
    3. PlayStation 4 Optical Drive Replacement: étape 16, image 1 de 2 PlayStation 4 Optical Drive Replacement: étape 16, image 2 de 2
      • Use your fingers or a pair of tweezers to disconnect the optical drive cable from the motherboard.
      Demander à FixBot
    4. PlayStation 4 Optical Drive Replacement: étape 17, image 1 de 3 PlayStation 4 Optical Drive Replacement: étape 17, image 2 de 3 PlayStation 4 Optical Drive Replacement: étape 17, image 3 de 3
      • Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place.
      Demander à FixBot
    5. PlayStation 4 Optical Drive Replacement, Remove the optical drive: étape 18, image 1 de 2 PlayStation 4 Optical Drive Replacement, Remove the optical drive: étape 18, image 2 de 2
      • Remove the four screws securing the optical drive.
      • Three 9.7 mm Torx screws
      • One 6.2 mm Phillips screw
      Demander à FixBot
    6. PlayStation 4 Optical Drive Replacement: étape 19, image 1 de 2 PlayStation 4 Optical Drive Replacement: étape 19, image 2 de 2
      • Lift the optical drive straight up and out of the PS4.
      Demander à FixBot
    1. PlayStation 4 Optical Drive Replacement, Remove the PCB: étape 20, image 1 de 2 PlayStation 4 Optical Drive Replacement, Remove the PCB: étape 20, image 2 de 2
      • If you purchased an optical drive with the PCB board and bracket included, skip the remaining steps and begin reassembly.
      • Remove the three 6.2 mm Phillips screws from the metal bracket.
      Demander à FixBot
    2. PlayStation 4 Optical Drive Replacement: étape 21, image 1 de 2 PlayStation 4 Optical Drive Replacement: étape 21, image 2 de 2
      • Lift the metal bracket straight up to separate it from the optical drive.
      Demander à FixBot
    3. PlayStation 4 Optical Drive Replacement: étape 22, image 1 de 2 PlayStation 4 Optical Drive Replacement: étape 22, image 2 de 2
      • Remove the 6.4 mm Phillips screw from the PCB board.
      Demander à FixBot
    4. PlayStation 4 Optical Drive Replacement: étape 23, image 1 de 2 PlayStation 4 Optical Drive Replacement: étape 23, image 2 de 2
      • Use the tip of a spudger to flip open the ZIF connector locking bar.
      Demander à FixBot
    5. PlayStation 4 Optical Drive Replacement: étape 24, image 1 de 2 PlayStation 4 Optical Drive Replacement: étape 24, image 2 de 2
      • Pull the ribbon cable straight out of the ZIF connector.
      Demander à FixBot
    6. PlayStation 4 Optical Drive Replacement: étape 25, image 1 de 2 PlayStation 4 Optical Drive Replacement: étape 25, image 2 de 2
      • Hold the PCB in one hand and the lower ribbon cable in the other.
      • Gently pull the lower ribbon cable straight out of the socket.
      Demander à FixBot
    7. PlayStation 4 Optical Drive Replacement: étape 26, image 1 de 2 PlayStation 4 Optical Drive Replacement: étape 26, image 2 de 2
      • Hold the PCB in one hand and the upper ribbon cable in the other.
      • Pull the upper ribbon cable straight out of the socket.
      Demander à FixBot
    8. PlayStation 4 Optical Drive Replacement: étape 27, image 1 de 1
      • Remove the PCB.
      Demander à FixBot
📌To reassemble your device, follow the above steps in reverse order.
204 autres ont terminé cette réparation.
Sam Omiotek
Membre depuis le 02/25/19
100 304 Réputation
289 tutoriels rédigés
74 commentaires de tutoriel
This was a great help after my 2 yr old put a coin in my PS4. However when following the steps backwards I got to step 7 which says 'Remove the 5 wire plug attached from the power supply to the motherboard' & couldn't see how to reattach it. I then noticed it looks like I've pulled the whole plastic white casing/plug holder (within the orange rectangle) off the mobo rather than just the plug from the casing. Although the pic looks like the plastic casing does come off the mobo as it's at an angle (maybe why I pulled the whole thing out or maybe I did it right).
I'm thinking I've made a mistake is because now I cant see anywhere that I can 'plug' the 5 L shaped wires on the bottom of the plastic casing back onto the mobo. Plus where they used to be attached there's now 5 tiny silver rectangles on the mobo (2 opposite 3), so I guess these 5 wires were some how adhered to those mobo rectangles by a conductive adhesive of some sort.
Any suggestion for the best repair method would be appreciated.
Thanks
doc browejnn - Réponse Partager
If you've pulled the female end from the motherboard the it need to be resoldered to the board, most likely gonna need to pull the motherboard. It's a very simple connector, sounds as if you yanked the whole thing off.
lynx2069 - Réponse Partager
Is anyone there who try to change the optical drive without change the Motherboard in the same time ? And does it run ?
Thanks for your help.
Frederic Morelli - Réponse Partager
How about a guide for replacing just the laser unit instead of the whole drive?
david.walker52 - Réponse Partager
I changed the drive with its motherboard, when I want to update the system, an error message appears:
CE-42116-8 .
rafat abulaeth - Réponse Partager
Nombre de vues :
Dernières 24 heures : 59
7 derniers jours : 404
30 derniers jours : 1,674
Total : 531,955
