Introduction
This guide shows how to remove and replace the joystick trim strips on your PlayStation Portal. These are the black plastic strips that surround each joystick.
Ce dont vous avez besoin
Before you begin repairs, power off your PlayStation Portal and unplug any cables.
Insert the tip of an opening pick underneath the left joystick trim strip, where it wraps below the grip.
Twist the opening pick to release the bottom clip.
Repeat the procedure to unclip and remove the right joystick trim strip.
Use your fingers to align and clip the top edge in place.
Firmly press along the remaining edges to clip the strip in place.
