Aller au contenu principal
PlayStation Start and Select Buttons Replacement
Ce dont vous avez besoin
  1. PlayStation Start and Select Buttons Replacement, Start and Select Buttons: étape 1, image 1 de 1
    • Before you begin, unplug your controller and console to avoid accidentally turning it on during disassembly.
  2. PlayStation Start and Select Buttons Replacement: étape 2, image 1 de 3 PlayStation Start and Select Buttons Replacement: étape 2, image 2 de 3 PlayStation Start and Select Buttons Replacement: étape 2, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the five 7.2 mm screws securing the rear cover.
  3. PlayStation Start and Select Buttons Replacement: étape 3, image 1 de 3 PlayStation Start and Select Buttons Replacement: étape 3, image 2 de 3 PlayStation Start and Select Buttons Replacement: étape 3, image 3 de 3
    • Gently push the rear cover towards the front of the #2 trigger buttons.
    • Lift the rear cover.
    • The #2 trigger buttons may come off when removing the cover.
  4. PlayStation Start and Select Buttons Replacement: étape 4, image 1 de 2 PlayStation Start and Select Buttons Replacement: étape 4, image 2 de 2
    • Lift the battery and set it beside the controller, with care not to strain the wires.
    • Use a Phillips #1 screwdriver to remove the single 7.2 mm screw securing the motherboard.
  5. PlayStation Start and Select Buttons Replacement: étape 5, image 1 de 2 PlayStation Start and Select Buttons Replacement: étape 5, image 2 de 2
    • Unclip the vibrating motors.
    • Be careful not to break the black and red wires connected to the motherboard. They are very fragile!
  6. PlayStation Start and Select Buttons Replacement: étape 6, image 1 de 2 PlayStation Start and Select Buttons Replacement: étape 6, image 2 de 2
    • Lift off the plastic housing holding the motherboard, battery, and vibrating motors.
  7. PlayStation Start and Select Buttons Replacement: étape 7, image 1 de 3 PlayStation Start and Select Buttons Replacement: étape 7, image 2 de 3 PlayStation Start and Select Buttons Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the rubber buttons with a pair of tweezers.
3 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 60
Total : 1,755
