Aller au contenu principal
Polar M400 Watch Screen Replacement
Ce dont vous avez besoin
  1. Polar M400 Watch Screen Replacement, Wrist Strap: étape 1, image 1 de 1
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
    It may be easier to push the pins out in one direction. Unfortunately, I do not recall which direction was easier…
    Nathan Gelderloos - Réponse
  2. Polar M400 Watch Screen Replacement: étape 2, image 1 de 2 Polar M400 Watch Screen Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
  3. Polar M400 Watch Screen Replacement: étape 3, image 1 de 1
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
  4. Polar M400 Watch Screen Replacement, Battery: étape 4, image 1 de 1
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  5. Polar M400 Watch Screen Replacement: étape 5, image 1 de 2 Polar M400 Watch Screen Replacement: étape 5, image 2 de 2
    • Gently remove the backing from the watch.
  6. Polar M400 Watch Screen Replacement: étape 6, image 1 de 2 Polar M400 Watch Screen Replacement: étape 6, image 2 de 2
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
    this shows how to take the battery out; what about replacing it nd securign the ‘electricity leads’ of the new battery to the watch?
    Yonatan G - Réponse
    Thanks, very clear straight forward steps
    mohamed elmosalamy - Réponse
    même remaque que jonathan
    pas assez de précision sur la remise en place des connecteur de la nouvelle batterie
    François Collet - Réponse
    Bonjour François, as tu réussi à remonter la batterie?
    Thierry Grandjean -
    Very strange you haven't completed the procedure.
    John Kirk - Réponse
    It says 'To reassemble your device, follow these instructions in reverse order' How difficult is that? So, put battery in, carefully fold contacts back, etc, etc....if that is not obvious, then please do not attempt this at all.
    Mark van der Giezen - Réponse
  7. Polar M400 Watch Screen Replacement, Screen: étape 7, image 1 de 2 Polar M400 Watch Screen Replacement, Screen: étape 7, image 2 de 2
    • Detach the screen from the screen protector using a PH000 screwdriver.
  8. Polar M400 Watch Screen Replacement: étape 8, image 1 de 2 Polar M400 Watch Screen Replacement: étape 8, image 2 de 2
    • Attach a new screen to the screen protector.
    • Make sure that the charging port remains accessible, as it can easily become detached during the replacement.
    hello and thanks for the tutorial. I need to fix the screen of a V800 polar and I have a screen of the m400. Do you think I can replace one with the other? Can you confirm what the same LCD is? Thank you very much for everything
    juan_dinio69 - Réponse
    Привет, под экраном есть два элемента, нужны их характеристики,позже отправлю фото, какие элементы перегорели.А вообще есть электрическая принципиальная схема polar m400?
    Game Pro - Réponse
    Where does even one get a screen in the first place?
    Christos Dimitrakakis - Réponse
    Bonjour,
    pouvez-vous me dire ou acheter un port usb pour remplacer sur montre M400 comme expliqué sur le tutoriel?
    Merci
    Denis
    judoclubbastogne - Réponse
5 autres ont terminé cette réparation.
Nicholas Sanders
Membre depuis le 09/28/17
513 Réputation
2 tutoriels rédigés
Équipe
University of Maine, Team S1-G3, Diaz Fall 2017 Membre de l'équipe University of Maine, Team S1-G3, Diaz Fall 2017
UMAINE-DIAZ-F17S1G3
4 membres
9 tutoriels rédigés
10 commentaires
Hi, where can i buy the replacement?
Thanks
Mario Sánchez-Barriga Marín - Réponse
hi,where can I buy the usb replacement.
GamesFISH_1989 - Réponse
Hi, were can i buy the replacement. Thanks
Julien Genon - Réponse
https://www.allsystem.cz/
I bought a connector USB there… Maybe can be interesting for someone else…
manuel caudera - Réponse
hello manuel,
i tried to order from the web site you specified, but it looks like they are not delivering in france,
cna you please tell me where else i can order this peice
Mathieu Poncet -
Polar won’t sell spare parts so where can I buy a replacement screen or a replacement front case for the M430?
Olivier Grand - Réponse
hello olivier,
did u find a resellor for polar spare pieces , i am looking for usb connector fo m400
Mathieu Poncet -
I destroyed the micro usb port on my watch (don’t ask..) I bought another used m400 for a very cheap price, because the screen protector was messed up - full of scratches. I switched the insides of the watches using your instructions. Thank you! I now have a working watch with a clean screen protector and an extra battery just in case I need one later.
Arttu J - Réponse
I damaged the star screw (STEP 4). What type is it? Where can I buy these star screws? well thank you
Radoslav Tengy - Réponse
Hi
where can i get a polar M400 Screen protector in Cape Town.
Cecil Geduldt - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 68
Total : 9,706
