Introduction
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Ce dont vous avez besoin
Use a coin to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
Place enough pressure on the upper case to allow you to slide a tool just within the seam between upper case and lower case as shown in the picture. A dentist's hook, push pin, or similar tool will work.
Delicately slip the tip of your tool behind the silver metal latch and pull it forward while pulling up on the case. This may take some effort.
Alternatively, you can free the clasp with a small flathead screwdriver through the CD slot. The clasp is 1-3/16 in (3cm) from the left side of the slot. Use the screwdriver to lift out (or press back) the felt lining; then use the screwdriver to pull the clasp (shiny metal) forward to free it from the catch behind it (dull metal).
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Rotate the upper case up and toward the screen, so that the upper case rests against it.
Disconnect the indicated 14 cables from the logic board, starting in one place and moving around the board.
Remove the following 12 Phillips screws from the logic board:
Six 4 mm around the edges of the logic board.
Two 5 mm securing the right speaker to the logic board (move the speaker off of the logic board).
Three 6 mm with wavy washers in the upper, left corner of the logic board.
One 4 mm underneath a black bumper in the back right corner of the logic board.
One 4 mm screw may not be present on some logic boards.
Grasp the logic board at the left edge with one hand and at the thinnest section with the other hand. Lift the left edge of the board up to approximately a 30 degree angle (if you don't have your protractor handy, just lift until the DVI port clears the right hinge).
Once the logic board clears the ports, slide it out to the left.
Use a firm plastic edge to scrape the thermal material off the processor.
For more advanced instructions on this procedure, see our Applying Thermal Paste Guide.
Remove the three Phillips screws securing the right fan to the metal framework.
2 autres ont terminé cette réparation.
