Introduction
Use this guide to remove or replace the right fan in your Razer Blade 15" (2020) laptop.
Note: This guide refers to the "right" fan as the one on your right-hand side when the screen is open and facing you.
Ce dont vous avez besoin
Unplug all cables and fully shut down your laptop.
Close the lid and flip your laptop over so the back cover faces up.
Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
Apply a heated iOpener to the battery cable tape for one minute.
Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
Grab the pull tab on the neck of the left-side screen connector and pull it straight out of its socket.
Pull the left-side screen cable out from the clips along the left edge of the fan.
Use tweezers to peel the right side of the fan tape from the heatsink.
Use a Phillips screwdriver to remove the two 6.7 mm screws securing the right fan.
Lift the lower edge of the right fan and slide it away from the heatsink.
Remove the fan.
