Introduction
The motherboard is one of the most important components of the Razer Blade Stealth 2016 (Part # RZ09-01682E20). The motherboard has connectors in which the other circuit boards will be slotted. Essentially, all components lead back to the motherboard. If the motherboard fails, then so can almost every other component in your Razer Blade Stealth 2016. This guide will show you how to remove and replace the motherboard.
Ce dont vous avez besoin
Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
Remove the rear cover by prying up lightly starting in one of the corners.
2 commentaires
Hi Sadie. It's complicated for me with the battery disconnector, I can't remove it. would you help me with that?
Hi @matiasurani. It looks like the connector is covered by tape so you might have to remove the tape first. The battery is connected to the motherboard by a press connector. Take a look at this guide for how to disconnect it safely. Thanks!
