Aller au contenu principal
Razer Kishi Phone Connector Replacement
Ce dont vous avez besoin
  1. Razer Kishi Phone Connector Replacement, Remove the screws: étape 1, image 1 de 1
    • The opening process is the same on both sides. For simplicity, this guide shows only the right-side opening process. Unscrew whichever side you wish to open and work on.
    • For the right side, remove the five Y0 screws securing the right side of the controller.
    • Four 9.2 mm screws
    • One 7.2 mm screw
    • If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
    • One 7.2 mm screw
  2. Razer Kishi Phone Connector Replacement, Release the bottom edge clips: étape 2, image 1 de 3 Razer Kishi Phone Connector Replacement, Release the bottom edge clips: étape 2, image 2 de 3 Razer Kishi Phone Connector Replacement, Release the bottom edge clips: étape 2, image 3 de 3
    • Both cases are held together by plastic clips.
    • Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
    • With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
  3. Razer Kishi Phone Connector Replacement, Release the side edge clips: étape 3, image 1 de 2 Razer Kishi Phone Connector Replacement, Release the side edge clips: étape 3, image 2 de 2
    • Slide the opening pick along the right edge to loosen the plastic clips.
  4. Razer Kishi Phone Connector Replacement, Release the top edge clips: étape 4, image 1 de 2 Razer Kishi Phone Connector Replacement, Release the top edge clips: étape 4, image 2 de 2
    • Slide the opening pick along the top edge to loosen the remaining plastic clips.
    • Don't try to remove the top side yet, the case is still connected to the board.
  5. Razer Kishi Phone Connector Replacement: étape 5, image 1 de 3 Razer Kishi Phone Connector Replacement: étape 5, image 2 de 3 Razer Kishi Phone Connector Replacement: étape 5, image 3 de 3
    • Carefully lift the top side and unfold it to the right, like a book.
  6. Razer Kishi Phone Connector Replacement, Disconnect the interconnect cable: étape 6, image 1 de 3 Razer Kishi Phone Connector Replacement, Disconnect the interconnect cable: étape 6, image 2 de 3 Razer Kishi Phone Connector Replacement, Disconnect the interconnect cable: étape 6, image 3 de 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    • Pull the cable out of the socket.
  7. Razer Kishi Phone Connector Replacement, Remove the screws: étape 7, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
  8. Razer Kishi Phone Connector Replacement, Remove the breakout board: étape 8, image 1 de 3 Razer Kishi Phone Connector Replacement, Remove the breakout board: étape 8, image 2 de 3 Razer Kishi Phone Connector Replacement, Remove the breakout board: étape 8, image 3 de 3
    • The breakout board is plugged in. When removing breakout board, it is important to pull it straight out to avoid bending the connectors.
    • Remove the breakout board by lifting it straight up, away from the controller.
  9. Razer Kishi Phone Connector Replacement, Remove the screws: étape 9, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
  10. Razer Kishi Phone Connector Replacement, Remove the trigger: étape 10, image 1 de 2 Razer Kishi Phone Connector Replacement, Remove the trigger: étape 10, image 2 de 2
    • Remove the shoulder trigger.
  11. Razer Kishi Phone Connector Replacement, Lift the shoulder button board: étape 11, image 1 de 2 Razer Kishi Phone Connector Replacement, Lift the shoulder button board: étape 11, image 2 de 2
    • Use a pair of blunt nose tweezers to lift out the shoulder button board.
  12. Razer Kishi Phone Connector Replacement, Remove the screws: étape 12, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the two 5.9 mm-long screws.
  13. Razer Kishi Phone Connector Replacement, Remove the board: étape 13, image 1 de 2 Razer Kishi Phone Connector Replacement, Remove the board: étape 13, image 2 de 2
    • Pull the mainboard straight out of the frame to remove it.
  14. Razer Kishi Phone Connector Replacement, Unfasten screws: étape 14, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the four 5.7 mm screws securing the phone bracket.
  15. Razer Kishi Phone Connector Replacement, Remove the phone bracket: étape 15, image 1 de 2 Razer Kishi Phone Connector Replacement, Remove the phone bracket: étape 15, image 2 de 2
    • Remove the phone bracket.
  16. Razer Kishi Phone Connector Replacement, Remove the rubber phone pad: étape 16, image 1 de 2 Razer Kishi Phone Connector Replacement, Remove the rubber phone pad: étape 16, image 2 de 2
    • Use your fingers to lift the rubber phone pad out sideways.
  17. Razer Kishi Phone Connector Replacement, Unfasten the screws: étape 17, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 4.6 mm screws securing the phone connector.
  18. Razer Kishi Phone Connector Replacement: étape 18, image 1 de 3 Razer Kishi Phone Connector Replacement: étape 18, image 2 de 3 Razer Kishi Phone Connector Replacement: étape 18, image 3 de 3
    • Thread the phone connector through its opening in the side of the controller.
    • Remove the phone connector.
2 autres ont terminé cette réparation.
Adriana Zwink
Membre depuis le 12/18/19
48 292 Réputation
167 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 818 tutoriels rédigés
2 commentaires
Where can I find this c type connector?
eric nelson - Réponse
Is it exactly the same on the kishi v2 or is it different? If yes how? And where can i buy that usb c port thats made for the controller to output the inputs?
HypeShadow Duck - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 18
30 derniers jours : 80
Total : 3,131
