Aller au contenu principal
Razer Kraken Ultimate Microphone Replacement
Ce dont vous avez besoin
  1. Razer Kraken Ultimate Microphone Replacement, Ear Pads: étape 1, image 1 de 3 Razer Kraken Ultimate Microphone Replacement, Ear Pads: étape 1, image 2 de 3 Razer Kraken Ultimate Microphone Replacement, Ear Pads: étape 1, image 3 de 3
    • Grab the ear piece from one of the sides and lightly pull it outwards.
    • Ideally, do not pull the ear piece directly away from the speaker; it may damage the piece.
  2. Razer Kraken Ultimate Microphone Replacement: étape 2, image 1 de 2 Razer Kraken Ultimate Microphone Replacement: étape 2, image 2 de 2
    • Once you have taken off one side, you can then remove the whole piece by slowly prying the pad away from the headphones.
  3. Razer Kraken Ultimate Microphone Replacement: étape 3, image 1 de 2 Razer Kraken Ultimate Microphone Replacement: étape 3, image 2 de 2
    • Repeat steps on the other side.
  4. Razer Kraken Ultimate Microphone Replacement, Speaker: étape 4, image 1 de 3 Razer Kraken Ultimate Microphone Replacement, Speaker: étape 4, image 2 de 3 Razer Kraken Ultimate Microphone Replacement, Speaker: étape 4, image 3 de 3
    • Remove the four 10 mm Phillips #00 screws securing the right speaker.
    • Be sure the device is unplugged before attempting to remove any of the screws.
  5. Razer Kraken Ultimate Microphone Replacement: étape 5, image 1 de 2 Razer Kraken Ultimate Microphone Replacement: étape 5, image 2 de 2
    • Remove the 10 mm Phillips #00 screws securing the left speaker.
    • Note that one of the screws is hidden behind the product information sticker. Use your screw driver to punch a hole in the sticker.
  6. Razer Kraken Ultimate Microphone Replacement: étape 6, image 1 de 2 Razer Kraken Ultimate Microphone Replacement: étape 6, image 2 de 2
    • To fully detach the speakers cut the wires as close as possible to the connection point, leaving plenty of room to solder the new speaker on.
  7. Razer Kraken Ultimate Microphone Replacement, Microphone: étape 7, image 1 de 3 Razer Kraken Ultimate Microphone Replacement, Microphone: étape 7, image 2 de 3 Razer Kraken Ultimate Microphone Replacement, Microphone: étape 7, image 3 de 3
    • Remove the two 10 mm Phillips #00 screws securing the microphone.
  8. Razer Kraken Ultimate Microphone Replacement: étape 8, image 1 de 1
    • Gently pry the bottom connection away from the casing with the iFixit opening tool.
  9. Razer Kraken Ultimate Microphone Replacement: étape 9, image 1 de 2 Razer Kraken Ultimate Microphone Replacement: étape 9, image 2 de 2
    • Pull the microphone down and out of the casing.
  10. Razer Kraken Ultimate Microphone Replacement: étape 10, image 1 de 1
    • Open up the casing the microphone retracks into.
    • Cut the cable as close to the microphone as possible, leaving behind enough to solder the new microphone to.
    • The casing the microphone if removed correctly in the previous step is easily opened by hand
Tucker Murphy
Membre depuis le 10/26/22
115 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-4, Petersen Fall 2022 Membre de l'équipe UMass Dartmouth, Team 1-4, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G4
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 27
Total : 540
